Few after swap issues.
  • avery0829
    • Dec 2008
    • 793
    (88 325is M52B28 OBD1)
    Overall it runs perfect! Finally it happened after so much talking, Im stoked!
    But.
    1. Coolant temp gauge is not working. I turn the key and it clicks up right away to the bottom of the blue and doesn't go any further. I'm using this
    And I grounded it also.
    2. Speedometer fixed.
    3. Clutch releases at the very bottom to the floor. It's been bled quite a few times. Does it need to be bled more possibly?
  • samiam3356
    • Jul 2009
    • 1901
    Your using the 1 prong sensor (e30) for the cluster correct? The picture shows a 2 prong and though its the picture off their site it can be misleading as it's not the right temp sensor in their product.
    Originally posted by Roysneon
    $5 shipped?
    Originally posted by MarkD
    You are a strange dude, I'n not answering any more posts from you.
      • 34835
      yeah, doesn't look like the right sensor. it should be a 1 pin sensor with a brown connector.
      • e30s50dan
        • Nov 2008
        • 2076
        yes... brown sender is what you need
        NASA
        BMWCCA member
        PCA member 25yrs
        1991 318IS slick top
        1997 M3 sedan
        2001 325CI DD
        “whoever turns the wheel the least, wins"
        • matt
          • 3731
          What got it started? Just curious.
          • avery0829
            • Dec 2008
            • 793
            Thanks, you guys are on point. I just checked and I have the 2 prong one. So I'll swap that out here soon.
            Any ideas on the clutch?
            The ABS power wire was getting grounded out some how causing the number 7 pin to not get power. I had a friend of mine help me out on diagnosing it, so I don't really remember the details.
            • 87e30
              • Jul 2008
              • 5676
              In for my clutch sucking too.
              I heard that you should take the slave off of the transmission when bleeding otherwise air gets stuck around the bend.
              Curious what people say. I haven't tried pulling the slave off yet.
              I just hate everyone.
              No need for discretion.
              • samiam3356
                • Jul 2009
                • 1901
                hmmm... I just put a new one on and put the slave on first and then the line and then bleed. Bled perfect and clutch is exactly where it should be. Super smooth, actually I think my old slave may have been working because I wasn't quite preppared for how easy, quite the clutch was. running a new m20 clutch on mine.
                $5 shipped?
                • e30s50dan
                  • Nov 2008
                  • 2076
                  you shouldnt have to wire up your ABS to get it to work..you have an 88IS,just ike mine,your abs should work fine...I think pin 7 is ground.
                  NASA
                  BMWCCA member
                  PCA member 25yrs
                  1997 M3 sedan
                  2001 325CI DD
                  • M-technik-3
                    • 18946
                    Pull slave out.
                    • e30s50dan
                      • Nov 2008
                      • 2076
                      oh,and not sure how you are bleeding your clutch,but i like the Motive pressure bleeder..I have done 2 swaps and have never had issues with clutch/brakes gl
                      NASA
                      BMWCCA member
                      PCA member 25yrs
                      1997 M3 sedan
                      2001 325CI DD
                      • monkeytaco
                        • Jan 2010
                        • 882
                        Bleed the clutch slave cylinder with it out of the transmission, the bentley describes the procedure. I bled mine with it on a LOT (about 30 mins of it) and after I took it out it and did it the way the bentley described it belched out a LOT more air bubbles. Your clutch will feel amazing if you do it that way.
                        Also, where did you get the part below? I've done some searching and can't find it.
                        Looking for a clean e30 shell for a project.
                        • avery0829
                          • Dec 2008
                          • 793
                          I personally didn't buy the adapter block thing. But its from Zionsville.
                          Thanks. I'll try that and when I do I'll post how it worked.
                          Originally posted by e30s50dan
                          you shouldn't have to wire up your ABS to get it to work..you have an 88IS, just like mine,your abs should work fine...I think pin 7 is ground.
                          If you wanted to look at my other thread about it not starting that will tell you a little more in depth.
                          • samiam3356
                            • Jul 2009
                            • 1901
                            zionsville i believe
                            oops to late
                            $5 shipped?
                            • matt325is
                              • 409
                              I saw you driving on 705 merging to I5 today. Sounded like you had minimal exhaust? Pretty sure it was you. Great looking car by the way ;)
                              Cheers
                              Matt
