s50 wiring issue
  • 325islovE
    • Feb 2007
    • 133
    s50 wiring issue
    i got a cranks no start car but some digging around in the adaptor i got, it seems i have a short in c101 pin 20 and 7 and they short to x20 pin 21. My question is what does pin 20 go to on c101(brown wire body side/green wire plug side)? dug around the etm for hours and cant seem to find it.
    C101 pin 7 should be hooked up to x20 pin 21 right?(ecu power)
    88 325is s50
    found this now page 62
    Should i cut the wire our should i just run a ground to that wire?
    1988 325is alpine
    1989 325is zinno RIP
    1992 325ic alpine
    1986 325e cirrusblau
  • blackhawkimpact
    • 2415
    Pin 7 is the ignition switch. What car o you have. Pin 20 is not used
      • 34844
      on late cars it goes to the ABS system to provide power
      on earlier cars it does nothing (including your 88 ).
      disconnect it
      • 325islovE
        • Feb 2007
        • 133
        thanks guys
        1988 325is alpine
        1992 325ic alpine
