e46 Flywheel on S50 swap?
  • kalib0y
    • Dec 2004
    • 3620
    I just wanted to throw this out there in case this would work and maybe it has been done before.
    I have a S50/tranny swap in my 89 and I also happen to have a new Fidanza Flywheel for an e46 that I have had for a while.
    Any way to make this flywheel work if I use another clutch? would I have any starter problems?
    thanks in advance and have a great New Year's!
    95 7.1L 16V E36 M3
    Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
    LIKE my Facebook Page! CLICK HERE
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    I'm using a flywheel that cam from an e46. Real oem says all the staters are the same between e46 and e36.
    http://realoem.com/bmw/partxref.do?part=12411740379
    • kalib0y
      • Dec 2004
      • 3620
      what clutch are you using?
      95 7.1L 16V E36 M3
      • 10Toes
        • Jan 2008
        • 61222
        Just the stock clutch and flywheel from a 2000 E46 328i.
        • Jason89i
          • Sep 2004
          • 875
          very cool.
          shameful advertising: i have an e46m3 flywheel and clutch w/ 30kmiles for $150 if anyone is interested.
          jason
          • M3 euro ltw
            Site Sponsor
            • 259
            hehehehe
            And if Jason sells his, and someone else needs one, I have one too, but buy Jason's first, mine has 32K on it. Besides, he's nicer than I am.
            (FWI the self adjusting clutch mechanism is a bit of work, and to install the clutch from one of these that has been already used, will require [I think] a special factory tool. I just put one of these on my 540, and once you undo the hold-back shipping retainer, it sets itself, and you better have aligned it properly)
            Speaking here of E46 M3 clutch.....
            Trying to make the world a better place, 6 TB at a time.
            http://abloriginalparts.com/
            • Andrew325is
              • Jan 2008
              • 1207
              I think the differences between the E46 M3 and non-m cars needs to be clarified. The input shaft spline is a larger diameter on the e46 m3 6-speed and therefore the clutch for that car will not work with the ZF 5-speed. My question is can you use an E36 or non-m E46 clutch with the stock E46 M3 flywheel? I read on another forum you can't but you can buy ltw flywheels that fit both the E36 and E46 M3's.
              Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
