m52b25 worth it?
  • jahnaboi
    • Oct 2006
    • 1742
    m52b25 worth it?
    Put a deposit with a friend on a 99 323is drivetrain for a very good price. 149k miles, starts and runs perfectly fine. Getting everything including the driveshaft (the car is stick).
    My question, is the juice worth the squeeze?
    We plan on turning this car into a track/fun car and are looking to boost this in the near future. We were looking forward to having a m52b28 to play with but the craigslist add was worded incorrectly.
    I doubt there is much power gains stock vs stock. What you guys think? Get errrrrr done?
    Adding s52 cams would be just as applicable as a m52b28 IIRC?
    -Jasper
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
  • blunttech
    • 12850
    I wouldnt. M52b28 is so cheap nowadays. Hold out if youre going to boost
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
    • monkeytaco
      • Jan 2010
      • 882
      There's no replacement for displacement.
      Looking for a clean e30 shell for a project.
      • phreshkid
        • 4655
        That's probably one of the worst sentences I've ever read
          • 34844
          the M52B25 out of the 323 is an extremely choked off version of the M50 family - it only puts down 170bph.
          if you did an ODB1 conversion to it you could eliminate most of that factor, but an M52B28 is definitely a better buy.
          • jahnaboi
            • Oct 2006
            • 1742
            We have the obd1 parts already. Everything down to the tee. If a m52b28 was available we would be on it, but at the moment there's none. Guess this will have to do. With obd1 bits + s52 cams, 3.5" hfm/chip/exhaust what do you think this will put out? Over or just about 200whp? Guess we'll have to see.
            • SpecM
              • Oct 2005
              • 4531
              it wouldn't be any worse off than an m50b25... once the obdII manifold is junked and a proper exhaust fitted
              if you get it at a good price, I say do it. It would pretty much be a m50tu, power-wise
              1989 cirrisblau-metallic 325i
              • jahnaboi
                • Oct 2006
                • 1742
                Yea, I figured it would be within the same power range. Top of my head, is the bore 84mm? Same bore size as the b28?
                • Leo_328i
                  • 226
                  Yeah all the 2.5 and 2.8 engines are 84mm bore.
                  You guys are very lucky in the states with such cheap engine prices! I'm down here in Australia and a M52 B28 worth buying is worth around $2000+ whilst M50 B25s/M52 B25s are closer to the $1000 mark.
                  I'm thinking of getting an M52 B25 soon, converting it to OBD1 and sticking it into my 318iS! We're luck that all our M52 motors are the alloy block which is a good 23kg lighter :)
                  Regarding M50TU B25 vs M52 B25 comparisons, excluding inlet manifold and OBD1/OBD2 differences, the M52 has a revised valvetrain which is lighter and is said to improve running smoothness and fuel economy according to official BMW literature. This includes conical valve springs and smaller lifters.
                  According to RealOEM, the pistons and rods are the same as M50TU B25.
                  Leo.
                  E30 318iS, E36 328i
                  • jbxblitz
                    • Nov 2009
                    • 52
                    does the m52b25 come with a forged crank?
                    • Leo_328i
                      • 226
                      No unfortunately, all the 2.5l motors use a cast crank. Its not really that bad a situation though, the rods are the items that are most likely to break and they are forged.
                      Leo.
                      E30 318iS, E36 328i
                      • blck325is
                        • Apr 2006
                        • 1749
                        Just got a m52b25, what else can I do after I do all this?
                        Originally posted by csermonet47
                        Vlad, you are handling this quite unprofessionally.
                        Also, you are a cock with tacky taste.
                        That is all.
                        • Sharino
                          • Jun 2005
                          • 186
                          Is converting a M52B25 to a M52B28 as simple as swapping out the crank or is there more to it?
                          www.eurowinnipeg.com
                          www.E30S38.com
                          E30 Mtec2-S38 | V10 TDI treg | E34 M5 | E39 M5 | Corrado turbo VR6
