I am very interested in doing this with my M52 and stock E36 oil pan. Is that something you could do or just S54 stuff for now?
Tubular Front Sub frame and Custom Pan for dual pump set up
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Tiny T those looks awesome! So this is a bolt in and the e34 dipstick and level sensor go right in ? What's this setup running $$$?
This could be the new way to do it.Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.Comment
Some pictures of the setup installed. The kit is built off of akg 24v swap mounts. These pictures have an e30 rack installed. I can make the subframes for the shorter mounts on the E36 racks as well though.
The drivers side sump modifications differ depending on the style of pan.
Thanks for looking!Comment
I will do an oil pan or subframe independent of one another, so don't feel like you can only get these modifications done as a package.
For people that want to do a rear setup but don't want to go with the S54 dual pickup I can modify E36 pans as well. Adding capacity is more challenging so I just do a notch on these. It will drop the capacity a quart, but shouldn't pose any issues.
I am waiting on a mockup engine to finalize the modification to the oil pickup then these will be available.
Don't forget about the 6 speed trans mounts either!
