Fan wiring
  • PuebloPete
    • Oct 2005
    • 161
    Fan wiring
    I know this has been covered and I have read a lot of threads pertaining to this question, but there's a lot of ways to do it and I just wanted to make sure I was doing this correctly. I have a pusher fan mounted to the radiator, I have removed the A/C.
    So here's what I was going to do, I was going to use the temperature switch in the radiator that used to run the aux fan. I was going to take the existing wiring that attached to the aux fan which was 3 wires, red, black and brown. I was going to tie together the red and black and connect that to the red on the new fan and then connect the two grounds...... ?? That should work correct? Thanks for any input.
    My build threads
    http://forums.bimmerforums.com/forum....php?t=1435735
    http://www.e30tech.com/forum/showthread.php?t=93896
  • samiam3356
    • Jul 2009
    • 1901
    Sounds right. Crazy to think you put red and black together and then tie it to red on the fan but thats it. Brown = ground on the chassis side and black = ground on the SPAL side.
    Originally posted by Roysneon
    $5 shipped?
    Originally posted by MarkD
    You are a strange dude, I'n not answering any more posts from you.
    • PuebloPete
      • Oct 2005
      • 161
      I know it. The funny thing is on the 87 and earlier everything is opposite. So I have a late model radiator, so I have to run the thermswitch accross the the pass side and the expansion tank float to the other.
      Question, would it be safe to assume that all brown wires on a BMW are ground? Would it be stupid to say that all brown wires, even with stripes of various colors are a form of ground?
      My build threads
        • 34835
        most of them are, but don't take it for granted - find a copy of the ETM for your car and look it up.
        • herlsy
          • Sep 2009
          • 339
          Best thing to do right here. The aux fan is usually a one-page diagram..
