Shaving flywheel!?
  • erik325i
    • Jan 2005
    • 3567
    Originally posted by 6gen91
    I'm still a little off on how much to take off.
    The amount of weight you remove is not the important factor in getting the flywheel to fit. You just need to make sure you have that chunk of steel on the backside of the flywheel machined off. Once that material is removed anything else is just optional.
    Also is that considered the "dual mass" flywheel? If i use a single, wouldn't i not have to cut anything then?
    This thread only applies to the single mass flywheel. You cannot really machine down a dual mass flywheel.
    • thebutcher37
      • 2877
      fotos for jew.
      STOCK FLYWHEEL (for comparison)
      lightened side
      Resurfaced/balanced
      Shaved lip comparison
      Inner mass removed comparison
      Hope this helps meng!
      Let me know if you can get it cheaper than I have found.
      Transaction Feedback
      • 416stroker
        • May 2008
        • 2448
        Originally posted by crazyvwobie
        cheapest setup? just grind a little off your oil pan and be done with it you will also save $100 or so at the machine shop,since you will have to have it balanced as well.
        It doesnt cost $100 It will more than likely cos $40 and least thats what I paied. I didnt have to be balence mine. Your removing an equal amount of material all the way areound.
        Mines pretty Much like the pic above but I dint make it concave. I just made it all flat in the back.
        84 318I Delphin RIP
        87 325IS delphin 24v Sold
        89 325 Alpineweiss
        • crazyvwobie
          • 298
          Depends where you live I guess.I was quoted $50 for removal of material and $50 for balancing.no offense but you are crazy not to balance your flywheel,considering the consequences if its out of balance.
          • 416stroker
            • May 2008
            • 2448
            Ya my machine shop said it would be fine because I didn't take off enough. Just made it flat to the ring gear its fine been driving it daily since I did the swap two years ago. They just told me it would be a waste of money. I trusted them and they were right.
            They do a lot of high revving circle track motors and shit. So I trusted then to do quality work.
            84 318I Delphin RIP
            89 325 Alpineweiss
            • erik325i
              • Jan 2005
              • 3567
              I agree. I would never machine down a flywheel and not have it balanced.
              • 416stroker
                • May 2008
                • 2448
                O well I don't doubt they checked it first. My car runs smooth as silk. Just idles low.
                84 318I Delphin RIP
                89 325 Alpineweiss
