my custom 24v intake set-up
  • UDelaware30
    • Dec 2009
    • 336
    Couldn't find a kit offered that looked good enough to buy, so i fabricated my own.
    I used:
    3" 90* elbow cut to size and two holes were drilled underneath to provide vacuum for the ICV and valve cover vent. This mounts to the MAF just like the stock intake boot.
    6" of straight 3" silicone. Mounts between the MAF and the air filter.
    K&N cone filter with a 3.5" base to clear the ABS pump.
    Used a nice sign i had laying around (aluminum alloy sheet metal) to make a heat shield to bring intake temps down.
    Left high beam was also removed and a black 6" inlet/3" outlet velocity stack is on its way to direct air into the "intake box". (Will be mounted in the high beam carrier.
    Will update when it gets here.
    P.S. all the shining dots in the first picture are shreds from the retro-reflective decal on the sign due to 10+ test fits before it was painted.
  • ChaseN
    • 709
    That's gonna be a bitch to clean.
    Looks good otherwise. I have to do something like this to the M3. Is the ABS pump still in the stock location?
    1991 318iS
    1992 911
    2006 330i 6-Spd ZSP people hauler
    Gone:
    1989 M3 S50B32, 6-Spd
    1990 325ix 5-Spd
    • UDelaware30
      • Dec 2009
      • 336
      It's a little difficult to remove the filter for cleaning, but I feel it's worth it.
      Abs pump is in the stock location.
      • ChaseN
        • 709
        No, I meant the dots, LOL
        1991 318iS
        1992 911
        Gone:
        1990 325ix 5-Spd
        • UDelaware30
          • Dec 2009
          • 336
          Haha I see, hopefully some compressed air will take care of that.
          • UDelaware30
            • Dec 2009
            • 336
            cleaned up a bit
            velocity stack in place of left high beam
            • Fusion
              • Nov 2009
              • 3659
              What do you guys think about putting one of these bastards in place of the high beam?
              • White325is
                • Oct 2006
                • 5947
                Hey I know that front end!!!
                • e46s54dr
                  • May 2008
                  • 1059
                  I like your idea about the intake boot. Any more info on this? Where did you buy the boot and what did you use exactly for the icv and vacuum fittings? How are they held in there? As for the hks filter, Id stay away from them. They definitely flow better, but they dont filtrate fine dust molecules as well as the paper filter. My buddy ran it on his r32 Skyline and when we removed the filters to clean them, The intake piping was black from dirt build up.
                  • Fusion
                    • Nov 2009
                    • 3659
                    I'm thinking track day swappable setup.
                    Since I have to put the headlight back for regular driving anyways.
                    • UDelaware30
                      • Dec 2009
                      • 336
                      haha cause you got me back on the road with a nice hook-up
                      thanks again mike
                      3" 90* 4 ply silicon elbow. Bought it from a local shop called verocious motorsports. I copied the positions of the 'nipples' from the bimmerworld intake. The icv nipple was a barbed water hose fitting from un-used obdII parts, the breather nipple was a 3/8 barbed t-fitting that i cut to be a straight barbed fitting. Both nipples are siliconed into the boot. So far they have been secure with no vacuum leaks.
                      • UDelaware30
                        • Dec 2009
                        • 336
                        cant drive my car currently :(
                        searching for a good deal on a getrag 260
                        • Adrian_Visser
                          • Jun 2006
                          • 2823
                          I'll have to snap some pics of my setup it's made of plastic though.
                          www.siliconeintakes.com sells all kinds of silicone charge piping and v-band clamps for DIYing this kind of thing up. I think it cost me $40 or $50 shipped for a 90, a short striaght piece and 4 v-band clamps.
                          I like your choice of fittings for the ICV and crank breather I used big bastardly plastic plumbing elbows. I wasn't too impressed with how it turned out. I just could never get myself to sacrifice a headlight though.
                          '89 Alpine S52 with goodies
