M52TU stroker ideas
  • dave.a.cote
    • Jul 2009
    • 246
    Correct - if you are using 84mm bore 2.8 pistons, not 2.5 pistons - and you have to shave 0.38mm off the top to get to 11:1. There is enough material there to do it, or at least that is what I did.
    1988 325 auto-x car
    1989 325ix winter car
    1991 525i summer car
    • ChaseN
      • 709
      Ok, so am I SOL on keeping my 2.5 pistons? Is there a difference between M52 and M52TU pistons? The BMW training publication I have says that the M52TU pistons are "carried over" from the M52, but RealOEM lists them as a different part number....Hmmmm
      BTW, thanks for all the awesome help/ideas guys
      1991 318iS
      1992 911
      2006 330i 6-Spd ZSP people hauler
      Gone:
      1989 M3 S50B32, 6-Spd
      1990 325ix 5-Spd
      • nrubenstein
        • 3148
        Seems like a lot of effort and money rather than just getting an M54B30 for a couple K.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
        • dave.a.cote
          • Jul 2009
          • 246
          Bah, where's the fun in that?
          1988 325 auto-x car
          • ChaseN
            • 709
            I can convert to OBD1, stroke, and maybe even snag a set of used cams with this motor for way less than I've ever seen a M54 priced at (that I would still have to convert to OBD1 & get rid of the return-less fueling system). Plus, to be honest, I want an engine to tear apart and fiddle around with.
            Also, knowing how much power you made on a OBD2 b25 with stock internals keeps me from wanting a M54 too much more.
            1991 318iS
            1992 911
            Gone:
            1990 325ix 5-Spd
            • nrubenstein
              • 3148
              The exact same setup on an M54B30 put down 217 at the wheels, FWIW. That's non-trivial. The amazing thing is that it pretty much hit peak hp at 5500 and ran it to redline.
              I'll be swapping in a 2.8 bottom end (it was free) at some point, so that'll be interesting to see.
              Edit: FWIW, the M52TU has a returning fuel rail which is plug and play on the M54 manifold should you end up using it.
              • ChaseN
                • 709
                I know the M54's advantage in power isn't trivial (BTW, very nice numbers), never said it was - in fact the M54 is probably my favorite pre-N series non-Sxx motor (I would run one over a US S5X in a heartbeat). Its just in this application I don't need the power vs. the extra cost, and though I would prefer it the $$ just doesn't make sense to me for the car it's going into.
                I really just want a moderately powerful, efficient, fun engine. I already find the car fun with an M20, IMO everything up from there is just a benefit. I've already got my M3 to tickle my "fast" itch.
                1991 318iS
                1992 911
                Gone:
                1990 325ix 5-Spd
                • nrubenstein
                  • 3148
                  Fair enough. I'll admit that I have an irrational desire to make a 2.8 M20. :)
                  • weaksauce
                    • Apr 2009
                    • 550
                    ok guys, i'm reading thru this and here is where I am at.
                    I have a 97 m52 out of a e39
                    full wiring harness for OBD1
                    and I can use either my s50 crank or the m52 crank in my build with the stock m52 pistons and rods.
                    will i gain anything with going to the s50 crank I have?
                    • Leo_328i
                      • 226
                      S50 crank will give you a longer stroke and increase your capacity to around 2.9l instead of 2.8. It would also increase your compression ratio.
                      Leo.
                      E30 318iS, E36 328i
                        • 34834
                        M52B28 pistons have very thick crowns, so you can machine them down without any worries at all.
                        if you've already got an S50 crank I think that is a no-brainer. The extra displacement is almost free.
                        • weaksauce
                          • Apr 2009
                          • 550
                          how about a thicker head gasket versus machining the pistons? seems like you could ge thte extra .5mm by going a .09 MLS gasket versus the stock .07 thickness, right?
                            • 34834
                            that's the wrong way to approach it IMO.
                            • weaksauce
                              • Apr 2009
                              • 550
                              wrong as in it won't work or wrong as in that just isn't the way you would do it? if it won't work, why?
                              you're only shaving .5mm off the top of the pistons, why not just lift the head .5mm and save the machining cost? i mean a .09 or a .1 HG isn't even that thick.
                              maybe i'll try it and report back when i've broken something.
                              • Hornung418
                                • 18
                                BUMP!
                                Why can't we remove the sleeve of the M52TUB28 and bore it out to 85.8 after re-sleeveing the cylinder wall? I think the key to the harmonic issue is to keep the Bore/Stroke square or under square, in the alloy blocks. So by bumping the Bore up to 85.8mm and the Stroke up to 85.8mm, you get a Displacement of 2.976 Liters and have a square stroke, hopefully avoiding the harmonic issues that plague the M54B30 when used as a track car.
                                Thoughts? Is it worth it?
