horrible gas mileage
  • lga714
    • 315
    I have an S50/ZF/3.25 and with some spirited driving and mostly cruising on the highway at 3500rpms I get about 8mpg...
    It only seems to be getting worse too. I'm concerned because I just got a job where I'd be driving all over the place day in day out. What am I looking at here?
    mtechII 5 lug S50
  • straight6pwr
    • Sep 2004
    • 3450
    concerned because something is wrong with your motor.
    • Sagaris
      • Sep 2009
      • 2243
      So many factors come into play
      Underinflated tires
      bad wheel bearings
      dragging brakes
      bad O2 sensor
      bad coolant temp sensor
      fuel leak
      • gregslow318i
        • Sep 2007
        • 1918
        Underinflated tires
        bad wheel bearings
        dragging brakes
        bad O2 sensor
        fuel leak
        bad tune
        bad maf
        and on and on and on.....
        looking for a e30m50 swap harness adapter pm me $150 shipped
        email nitroman12@gmail.com
        • LowR3V'in
          • 4209
          Maybe stop cruising at 90mph.
          • lga714
            • 315
            Damn I could spend a grand trying to tackle this problem.
            mtechII 5 lug S50
            • hoveringuy
              • Dec 2005
              • 2743
              No. Start with the simple things. What do your spark plugs look like?
              Go on a decent drive, park without idling and read the plugs.
              Will the car coast decently in neutral?
              My guess is the MAF.
              • dsobering47
                • Oct 2007
                • 697
                Do you have access to a fuel pressure gauge? Maybe your FPR is bad and overfueling...
                • lga714
                  • 315
                  Well the head was rebuilt with all new plugs with less than a 1000 miles on them. I'll take a look at all of that tomorrow. I have a spare MAF that I'll swap in the meantime. Could a bad TPS be the culprit?
                  mtechII 5 lug S50
                  • lga714
                    • 315
                    Also, I should note that the gauge fluctuates during the drive. For instance, today I started it up and it was just under 1/4 tank, as I drove a few blocks the gauge read at about 1/3 tank. By the time I was done driving (~25 miles) I was near empty.
                    mtechII 5 lug S50
                    • Dominic49
                      • Feb 2007
                      • 1373
                      i get better than that (sometimes) in the turbo s50 race car
                      • lga714
                        • 315
                        thank you Dominic lol
                        mtechII 5 lug S50
                        • ck_taft325is
                          • Sep 2007
                          • 6880
                          I'm right at 23mpg with mostly 50mph roads, S50/ZF320/S3.46...
                          Definately check the MAF.
                          Need a part? PM me.
                          • e46s54dr
                            • May 2008
                            • 1059
                            I'm not exactly sure on how the on board computer calculates mpg but my e30 was guzzling gas like a beast. I mean an insatiable beast. Turned out my fuel line was leaking from both the fuel rail and the fuel filter. I ended up replacing the whole system of lines. Not too hard or expensive if that's your case.
                            • lga714
                              • 315
                              Hah my OBC is worthless so I reset my trip odometer each time I fill up then divide by whatever amount of gallons I used. I haven't seen a drop of anything on my parking spot so I've ruled out leaks.
                              Will update the thread tomorrow.
                              mtechII 5 lug S50
