Another brake booster question
  • Gnarles
    • Dec 2008
    • 342
    It's an ATE, not a Girling. That shouldn't be a problem at all. I can pull the input rod out of the booster to do this work, correct?
    Hmmm, maybe it's a certain year range that has the flared input rod? I'm not sure if you can remove the input rod, I did the mods to it with it attached to the booster. Good luck!
    • FredK
      • 14761
      If it has a flared input rod, you can die it down to M12x1.5mm first, carefully file the threads flat, then use the M10x1.5mm die on it.
      • Jand3rson
        • 37587
        We're not even going to bother with that. We started by cutting the rod off of the 944 booster, and we were going to chop out a section, thread it down a bit more, and then weld it back together. So we've got the threaded part in the lathe, turning it down so I could buy a die and thread it down farther, and Andrew realizes "aren't we just making a M10x1.5 bolt?"
        So tomorrow, I'm going to go buy an M10x1.5 bolt, and we're just going to weld it onto the end of the input rod that we cut off.
        • FredK
          • 14761
          Welding works too. It's probably the fastest way. Just set the weld joint up for good penetration by chamfering both sides of the rod and bolt.
          • BMW_TUNER
            • Jul 2006
            • 1386
            Having welded one I have one tip. Soak a shop towel in water and leave it wrapped around the shaft as close to the booster as possible. Its cheap ins. over what happened to a friends booster (leaky Leaky).
            1989 332IS -S-Fiddy Four-Some weight removed.
            5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
            • StereoInstaller1
              GAS
              • 22679
              This is the best way to go, if you can get one. I just got one on Craigslist last night for $30.
              bastard
              Closing SOON!
              Thanks for 10 years of fun!
              • green
                • Dec 2010
                • 128
                What about moving the stock booster 1/2" away?
                • Jand3rson
                  • 37587
                  You can do that, and people have. Part of the reason I wanted the 944 is because it's smaller, looks a little better in the engine bay and has the same power as the stock one. And it was dirt cheap.
                  • 87e30
                    • Jul 2008
                    • 5676
                    Josh,
                    It's pretty easy to step down the the booster rod with a die. Personally I stepped it to 7/16ths I think and then enlarged the clevis just slightly.
                    I went to a machine shop and a welder and spent a couple days dealing with the problem... when in the end I just did it myself in my garage with a 15 dollar tap and die.
                    I just hate everyone.
                    No need for discretion.
                    • 10-66kruk
                      • Nov 2009
                      • 434
                      Now I don't fully know if this will work. But it's quite interesting it's the brake booster eliminator kit....I'll understand if I get flames for it but it does look pretty sick.
                      sigpic-Thanks warren
                      • Massive Lee
                        • Sep 2006
                        • 6785
                        ^^^The topic is about swapping boosters. Not removing it and fitting an MC directly on the firewall. Your link simply shows a square plate with holes. Which is also a method people have successfully done here. But nothing comes for free. You'll have to compensate somewhere for the lack of assist.
                        massivebrakes.com
                        • Jand3rson
                          • 37587
                          Originally posted by 87e30
                          Josh,
                          Yeah, it ended up taking us collectively about a half hour of time and 30 minutes to cut the rod off and weld on an M10x1.5 bolt.
                          • Xaq
                            • 45
                            hmm, I fitted a 924 booster and only had to cut off about 3/8" of threads. that's it.
                            • Jand3rson
                              • 37587
                              So when you bolt the booster rod back up to the brake pedal arm, you want the brake pedal arm extended all the way out, right?
                              • FredK
                                • 14761
                                Yes, you preload it such that it hits the brake light switch.
