Swap starting with full S50 M3; what should I pull?
  • Overlord475
    • Dec 2010
    • 799
    Hey guys,
    I have the opritunity to have at a 1995 E36 M3.
    Looking to do a 24v swap into my E30.
    What should I grab off the car?
    Engine
    Harness
    ECU
    Trans
    Etc...
    I know that I need an E34 525i oil pain and other bits and peices from other cars.
    Just wondering what all I should pull from this E36
    Thanks guys!
    --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
  • phreshkid
    • 4655
    2 door or 4 door? Did they even make 4 door s50 m3s?
    Grab the driveshaft too if it's a coupe.
    • nrubenstein
      • 3148
      Grab the driveshaft, but you'll need a 6-bolt (Z3) flange to use it.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • Overlord475
        • Dec 2010
        • 799
        A Z3 flange for what? The LSD?
        The trans is a 3 bolt and the LSD is a 4.
        The length will work for an E30 though. I've read that most people use either an E30 M3, 87-88 325e, or 96-98 E36 328 drive-shafts with the M3 ZF trans.
        • e30s50dan
          • Nov 2008
          • 2076
          rad !?
          NASA
          BMWCCA member
          PCA member 25yrs
          1991 318IS slick top
          1997 M3 sedan
          2001 325CI DD
          “whoever turns the wheel the least, wins"
          • Chistakoff
            • Jan 2011
            • 45
            http://www.rmeuropean.com/bmw-e30-m50-swap.aspx
            This will have all the information to do your swap..pm me with more questions
            • Overlord475
              • Dec 2010
              • 799
              Ya, I found that the other day! Great right up.
              PM sent
              • Chistakoff
                • Jan 2011
                • 45
                Yes sir it is..
                • herlsy
                  • Sep 2009
                  • 339
                  Might as well grab the steering rack while you're at it.
                  • StereoInstaller1
                    GAS
                    • 22679
                    EWS/Key
                    Closing SOON!
                    Thanks for 10 years of fun!
                    • Mike The Bavarian
                      • 488
                      the whole car. then part it after.
                      • StereoInstaller1
                        GAS
                        • 22679
                        I disagree with LOTS of stuff on this site. For example, a 944 booster gives you the same clearance and feel like stock, far better choice. Also, since we now can buy a pre-made tranny brace, that part of the equation is moot.
                        Closing SOON!
                        • Overlord475
                          • Dec 2010
                          • 799
                          Decided to go with a different set up.
                          Here's what I got:
                          S50US 3.0L M3 Engine w/ 70k miles (overhauled)
                          - New main and rod bearings
                          - All new timing components
                          - Rebuilt Cylinder head
                          - Rebuilt Vanos Unit
                          - New Belts, Tensioner
                          - Spark Plugs, coil pack connectors, and coil packs
                          - E34 oil pump, pan and dip stick
                          - New gaskets and seals
                          - New Water Pump, Thermostat, Metal Water Neck
                          - Euro Oil Filter Housing with Oil Cooler, AN-8 Lines, and Oil Cooler
                          - New Air Flow Meter
                          - All New Sensors
                          - E30 Gauge temp, E36 FI temp, O2 sensor
                          - Custom E30 S50 Wiring Harness
                          - Wiring harness is configured for your E30, Plug and Play, All connections labeled for easy install
                          - 16" Cooling fan
                          - Stainless Steel Headers
                          - E36 Throttle Cable
                          - E28 Engine Mounts
                          - Coolant Hoses
                          - Light weight single mass Flywheel, with new clutch kit
                          The only things I need to finish it out it:
                          - 325ix brake booster or modified E21 320i
                          - exhaust from headers back
                          • Chistakoff
                            • Jan 2011
                            • 45
                            Agreed with the 944 booster and Iposted it for a reference to assure they can get a lot of the little.stuff out the way also
                            • StereoInstaller1
                              GAS
                              • 22679
                              There is so much info on this swap now, compared to 5 years ago when I started learning...
                              BTW, welcome to R3V!
                              Closing SOON!
