Spal Fans
i got mine from ebay for pretty cheap and it was a pusher and a puller. that way i had options for placement. i went with making it a pusher so i would have room to work on the front of my motor and made a shroud so that i didnt loose any air and that every inch of my radiator gets air. not just the circle spot in the middle from the fan.
i used a 16 in spal fan-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good lookingComment
do you still have AC?i got mine from ebay for pretty cheap and it was a pusher and a puller. that way i had options for placement. i went with making it a pusher so i would have room to work on the front of my motor and made a shroud so that i didnt loose any air and that every inch of my radiator gets air. not just the circle spot in the middle from the fan.
i used a 16 in spal fan95 7.1L 16V E36 M3
Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
LIKE my Facebook Page! CLICK HERE
no i dont. but moving the ac stuff forward (im guessing in your case you have it) should not be hard.
OR-
i would remove the AC fan and then mount the spal fan in front of both the AC cooler and the rad, and make a shroud that would cover both. that way you use one fan and get the job done, and still have room in front of your motor to work-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
Got Drop?? ;-)
Looks like they've got the best price on them, too! I'm likely going to go with their 16" low profile push. Before I pull the trigger, is there any reason or definite advantage to going with a pull rather than a push, or vice-versa? To be honest, I'm inclined to go with the push because of it's location, it will hardly be seen.
Also, would it be a good idea to also get the Spal fan shroud gasket:
And I'm thinking the Spal mounting kit as well, looks like a better method than the zip-tie things:
I got something in the works right now. As soon as I get it all working I will post up the details.
The plan is to use a 16in 3600cfm pusher in front of the condenser and a 10in 1200cfm puller, along with a mishimoto rad, and 75degree thermostat. The car should not run hot at all, I hope95 7.1L 16V E36 M3
Puller fans are a much more efficient design, but they are a definite bastard to fit in there.
With a decent radiator and a decent pusher+gasket, you will have plenty of cooling.-Dave
2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
Need some help figuring out the ETM?Comment
That is waaaay overkill.I got something in the works right now. As soon as I get it all working I will post up the details.
And Josh, puller fans are more efficient (not really because of fan design, but because of how they're mounted) but you can get away with either one.paint sucksComment
Wow, I was away 1 day and I feel like I missed so much...thanks cleaning it up95 7.1L 16V E36 M3
Im going 16" spal puller Josh.Comment
http://store.bimmerworld.com/spal-fa...kit-p1358.aspx
im going to be running the mishimoto e36 rad with a 16 spal. did you ever figure out if these two linked items are needed or a better option than others?FOR SALE: diamantschwarz metallic 1991 m52 e30
silbergrau metallic 2004 330i ZHP
