Okay so I've got a problem with getting my M50 318iS trough emissions here in AZ. First time I went there it turned out I didn't have an evap system but the emissions themselves were fine. Then, on the same day, I went to my mechanic and he put in an evaporizer from a e21 he had laying around. He didn't even hook it up to the manifold, just to the fuel tank for the pressurization test at emissions.
He also grounded the small wire at the started because of an issue I had with the unloader circuit (no power to windows and A/C). So back I went to the emissions check and it passed the equipment test but then royally failed the emissions itself (values below). So back I went to my mechanic, he disconnected the wire from the starter from ground but didn't connect it back to the starter on the original position. The third time I went back to the emissions was pretty much the same as the second, way to high on the emissions, and also my A/C sporadically had power. So my question is is it possible the car somewhere thinks its in cold start enrichment all the time because the cable at the starter is grounded? Can I disable this somewhere? I'm in AZ so I don't need it really.
values:
first time:
HC: 0.45
CO: 3.94
NOX: 0.36
second run: (third comparable)
HC: 2.24 FAIL (limit 1.00)
CO: 28.80 FAIL (limit 12.00)
NOX: 0.88
values:
first time:
HC: 0.45
CO: 3.94
NOX: 0.36
NOX: 0.88
