Correct me If, I am wrong...240 tranny help
  • Matt-B
    The Waffler
    • 3856
    Ill be using my 240 transmission for my m50 swap here pretty soon.
    So I have a lightened single mass 325 SETA flywheel. Shaved to clear pan.
    -e30 m3 clutch and PP (might just buy a brand new m20 clutch)
    -325/323 Throw out bearing
    -240 slave (same as 260)
    -240 pilot bearing? Need to make sure, I need the 240 one...
    and what flywheel bolts can I use? my old ones? and the spacer?
    thanks guys
  • RedHoodRidah
    • Feb 2006
    • 1096
    When I ran my g240 I used stock m50dual mass and clutch setup. g240 slave and g260 shift linkage. e36 325i manual driveshaft.
    92 Granite Silver Vert
    M60B40 5spd
    • Matt-B
      The Waffler
      • 3856
      i have e36 325i shaft, just wondering on flywheel bolts and the the TO bearing, and pilot bearing.
      • blackhawkimpact
        • 2415
        240 pilot bearing
        323 euro TO
        Buy new flywheel bolts (11227805885). These are the one I ran on my single mass flywheel
        • RedHoodRidah
          • Feb 2006
          • 1096
          I ran a stock e36 325i TOB but that was because I ran the clutch setup from the car.
          M60B40 5spd
          • Matt-B
            The Waffler
            • 3856
            cool thanks guys. When Done Im going to do a mini write up on using a 240 w/ m50 cheers!
            I checked part #s
            Euro 323 and 89 325i TO bearing are the same. Cool.
              • 37829
              I'd run the taller 533i TOB personally. Not sure of the part number off hand.
              Also, you do not need to buy brand new bolts. I don't care what anyone on R3V tells you, I've done more flywheel removals and installations that anyone on the board I would bet.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • drumad
                • Aug 2009
                • 1700
                I think the pilot bearings you need are either
                11211709681 with dimensions 12x32x10 IF manufactured BEFORE 9/90
                or
                11211720310 with dimensions 15x32x10 IF manufactured AFTER 9/90
                edit: I would measure your g240's input shaft just to confirm however
                2008 335i - n54b30
                1991 318i - m52b28
                1994 fzj80 - LAND CRUSHER
                • 328ijunkie
                  • May 2007
                  • 3961
                  BMW states multp places these are TTY and with the crank harmonic issues the 24v motors have i would never risk that. Ive seen what happens when it goes wrong.
                  Check Us out on Facebook
                  Full Product Line Tuning
                  • Matt-B
                    The Waffler
                    • 3856
                    or
                    My Car was march/april of 1990...so Im fine then right.
                    • drumad
                      • Aug 2009
                      • 1700
                      Seems so, but I would measure the shaft first just to be sure. Alot of the info I've gathered has not been definite and many times it's been different for plenty of people using the g240. I'm in the same boat as well when I begin my swap in the next week or so.
                      2008 335i - n54b30
                      1991 318i - m52b28
                      • Mr.SWISS
                        • Nov 2005
                        • 1251
                        Not E30 but I did an M44->M52 swap on a Z3 and i just used the M52 dual mass and clutch kit. The TO's are the same.
                        Originally posted by 325Projectz
                        don't listen to the diagram... listen to mr. swiss.
                        :nice:
                        • Matt-B
                          The Waffler
                          • 3856
                          hmmm, ill keep looking
                          • e30s50dan
                            • Nov 2008
                            • 2076
                            just order both pilot bearings...they are cheap enough,... i wouldnt want to hold up my swap because of a $10 bearing..running S50 G240 E36 325ds 323to M20 shaved around 15lbs.....so far....so good!
                            NASA
                            BMWCCA member
                            PCA member 25yrs
                            1991 318IS slick top
                            1997 M3 sedan
                            2001 325CI DD
                            “whoever turns the wheel the least, wins"
                            • drumad
                              • Aug 2009
                              • 1700
                              Good idea. I'm doing exactly the same set up as you except with a m52 power plant.
                              2008 335i - n54b30
                              1991 318i - m52b28
