coolant reservoir solution
  • BADCLOWN
    • 399
    what are you all doing about the coolant reservoir with your 24v swaps?
    im going to be running a mishimoto rad with a single pusher fan. are you all just running an OE coolant res with the leveling sensor? mounted where?
    FOR SALE: diamantschwarz metallic 1991 m52 e30
    silbergrau metallic 2004 330i ZHP
  • z31maniac
    • 17566
    Mounted in the stock location.......
    www.gutenparts.com
    • samiam3356
      • Jul 2009
      • 1901
      Originally posted by Roysneon
      $5 shipped?
      Originally posted by MarkD
      You are a strange dude, I'n not answering any more posts from you.
      • BADCLOWN
        • 399
        so i can retain the m42 bottle?
        • MattM
          • Apr 2009
          • 931
          the M42 res was part of the rad if im not mistaken, you can use the entire rad. Or if your going mishimoto you will need a res from any late model M20 powered car.
          Full Build Thread Here
          • BADCLOWN
            • 399
            thank you for the clarification
            • Mr.SWISS
              • Nov 2005
              • 1251
              Umm stock location could be 4 different places. M10 cars and early m20's have a bottle on the pass strut tower, later M20 cars have a square res over the drivers fender well, E30M3's have it over the battery tray and M42's are integrated into the radiator.
              Ya damn dumbass being a smart ass.
              Originally posted by 325Projectz
              don't listen to the diagram... listen to mr. swiss.
              :nice:
                • 34844
                And? Any of those places will work.
                • MattM
                  • Apr 2009
                  • 931
                  not easily, the late model tank fits best in its stock location which is on the driver side fender in front of the strut housing.. You will need to buy the little clip that holds the tank on from a dealer... i believe its like $2 max...
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    This is the proper answer. coolant res and clip for an 1989 325i is perfect.
                    :nice:
                    • 325issguy
                      • Dec 2005
                      • 261
                      Im running the m42 rad. with good results
                      • Chrisv006
                        • 375
                        I have the late model tank mounted in an early model in the battery tray...made some simple mounts and it appears to be working great.
