the S50 motor have when it's sitting in the e30? I'm sure the m20 has more clearance right?
How much ground clearance does....
Tags: None -
Probably but its not THAT bad man. Im not sure if its really all that different.
There is how it sits compared to the steering rack. Just compare to your M20 pan.Im now E30less.
sigpic -
I am building a custom oil pan just for that reason, I don't like it being the lowest part of the car. Hopefully it will be done in a month and will take some pics when completed. Part of the reason the pan is deeper is it holds like 7-7.25 qts. The low oil pan could be an issue if your car is really low.Comment
Haha, really? Custom?
Why not just get a proven pan with its own baffle and clearance and just slat the skid plate over it, then your WHOLE front subframe is protected. Seems like money better spent.
Mtriple and Blunt have both been able to fit the skidplate over it IIRC.Im now E30less.
sigpicComment
trent
Don't drive like an idiot and you won't have a problem with the pan.
That said, I had custom plates welded to the bottom of my pan for added protection.
A custom pan isn't necessary. If you bring up the bottom of the pan are how is the oil pump fitting?
All I have to do is shorten the sump pipe a little bit, won't be very difficult. As for the proven baffles, they aren't complex at all so copying them will be easy. I just don't like the fact that the oil pan could scrape on slightly above average speed bumps.Comment
wordOriginally posted by f u z zthats why you gota drive sideways like i do over speed bumps.
Doing something M50 related? -> http://www.addissimo.com
On Myspace? ->http://groups.myspace.com/r3vlimited
BF2142 SN = BillyGooseComment
