Tachometer
  • ck_taft325is
    • Sep 2007
    • 6880
    An '87 ETA wont work in an I because of the coding plug IIRC. The issue comes about that you're reading entirely wrong. I ran a Moto '84 cluster in my S50 '86 and was fine but the RPM's where WAAAAY off. I could touch back to 1000rpm before I felt the engine slug at all.
    Need a part? PM me.
    • PuebloPete
      • Oct 2005
      • 161
      Yeah, I know, I think the eta also has a redline of 5k? I think you can just change the coding plug as well. But I'll look for an i.
      My build threads
      http://forums.bimmerforums.com/forum....php?t=1435735
      http://www.e30tech.com/forum/showthread.php?t=93896
      • Nairb
        • 1213
        Sorry to bump, but wanted a little clarification..
        Running an s52 with a 318is cluster.. I think my RPM's are running way high.. car reads idle at about 1500 RPM.. when I take off it seems like the RPM's are going up way too fast, and when I go beyond 7k RPM the needle starts bouncing around like crazy, but I feel like the car has so much more to go in sound, feel and power.. Do I need to swap a coding plug or do I need to rewire something?
        When the car is idling, it definitely does not sound like a 1500 RPM idle..
        My 1991 318is Progression Thread
        • jeffmn8
          • Jul 2010
          • 217
          I had the exact same thing with my car with an s50 and the 318is cluster. Swapped in a 325i coding plug and it works perfectly.
          Midwest Spec E30 #64
          https://www.facebook.com/thestickergarage
          • Nairb
            • 1213
            Awesome, thanks man.. will swap it and check back in!
            • blacked_e30
              • 85
              i had this same shit happen to me all it was was a fuse i felt dumb but worth a try :)
              " I'm not racing, I'm driving asshole"
              :hitler: Das Führer
              • Highway1
                • Jan 2009
                • 773
                ^ yup, does your radio work?
                • blackhawkimpact
                  • 2415
                  I also took off that yellow connector and now my tach no workies. :-(
