cps problem
  • 325islovE
    • Feb 2007
    • 133
    cps problem
    went to test my crank position sensor and i get no resistance between pin 1 and 2, ive tried on three different cps and get nothing, is this normal if its dead, i would expect some resistance on at least one of the sensors, one of them is only 2 months old. Am i testing it wrong?
    1988 325is alpine
    1989 325is zinno RIP
    1992 325ic alpine
    1986 325e cirrusblau
  • Adrian_Visser
    • Jun 2006
    • 2823
    These are OBDI VR CPS's with only two pins right? Are the leads on your multimeter plugged into the right spots? Is the meter set to the right range?
    I would say that yes without a doubt you are testing them wrong if these are two pin cps's
    '89 Alpine S52 with goodies
    • 325islovE
      • Feb 2007
      • 133
      i think its a hall sensor, 3 pins and its magnetic at the tip...
      I double checked my multi meter, used all the ranges, busted out my old cheepy multi meter tried that one through its ranges, i get proper resistance on other components
      I must be testing it wrong though no way i have three shit cps with no reading... unless thats what they read when these things crap out
      1988 325is alpine
      1992 325ic alpine
      • 325islovE
        • Feb 2007
        • 133
        fixed
        replaced multi meter bat. and retested, the new one i spent 80 bucks on is dead w/no reading old reads 505 ohms
        1988 325is alpine
        1992 325ic alpine
