C101 pin 7 has 2 green wires?
  • e30rapidic
    • 2167
    I grabbed a C101 pigtail form the junkyard to do my S50 swap as well as a M50 Vanos harness many months ago and just now getting ready to do the wiring. The question I have is that on the C101 connector, pin #7 has two green wires coming off of it. I haven't looked at the harness in my car yet but is this double green wire normal? One is heavier gauge. Do they both go to the same pin on the X20 connector? I'm still working on the pinouts for the X20 side.....this is what I have so far
    My e30 has a build date of 12/86.
    C101 pin out number on left and corresponding X20 pin out number on right
    pin color description m50 pin
    1 blue alternator 25
    2 green/yellow oil level (static) 1
    3
    4 brown coolant temp 12
    5 brown/green oil pressure switch 23
    6 green/white fused power 22
    7 green ignition coil 1 big, 1 small 21
    8
    9
    10 blue oil level (dynamic) 2
    11 white/green service lights reset 7 not sure about this one???
    12 grey CEL 8
    13 green/violet fuel pump 13
    14
    15
    16 white/black SRS (unused) 19
    17
    18 black/yellow starter 18
    19
    20
    Please let me know your thoughts, hopefully I'm not too far off. Thanks
    '87 325ic, powered by S50.
  • 325islovE
    • Feb 2007
    • 133
    Pin 7 to 21 should be fine just using the one larger guage wire. Just double check you get bat. voltage coming out the other side when youre done.
    pin out looks ok, but triple check everything for your car and engine saves you head aches in the long run... you could burn up your ecu if something is wired wrong, ask me how i know.
    1988 325is alpine
    1989 325is zinno RIP
    1992 325ic alpine
    1986 325e cirrusblau
      • 34839
      the only ones missing are the econometer (8 ), RPM (9) and VSS (14). I think these come from the C104 on the early cars? But you want to hook up the VSS at the very least, or the ECU can go into limp mode. eta's don't have unloader relays, correct?
      • e30rapidic
        • 2167
        thanks guys...
        I think I remember the econometer coming off the c104 plug......also I have no pins in 8, 9 or 14....only those pins I listed have anything in them.
        My car is an i, not an e, so it does have unloader relays.
        • e30rapidic
          • 2167
          now I've confused myself. Will my oil level sensor work with this setup? I've seen harnesses where there are 2 extra wires that run to the oil level sender.
          • 325islovE
            • Feb 2007
            • 133
            you have static and dynamic pluged in the same spots as mine, and then the last pin is grounded to the chasis, not sure if it will work as i havent driven the car yet but thats what i got in my adaptor from ericT.
            1988 325is alpine
            1992 325ic alpine
            • e30rapidic
              • 2167
              Talked with EricT (nice and helpful)...and that's exactly what he told me. If you are running an e34 harness it will work!!! awesome
