S52 OBD1 cranks but won't start
  • hammslice
    • 120
    #61
    Originally posted by Jason89i
    x20 p7 . . . sw/vi . what did you do with this? its for the start imobilizer.
    did your 94e36 x20 have (2) green wires or (1) gn and (1) sw/vi? your notes are conflicting.
    The notes that mention two green wires was me tracing the colors through the stock c101 because not every wire maintains it's color from the engine to the body.
    Pin 66 on the dme is SW/VI. What kind of signal/when is this wire looking for?
    I think this is where I goofed. I have the immobilizer SW/VI hooked up to SI reset BL/WS. And SI reset WS/GN hooked up to WS/SW. Speaking in the direction from motor to body. Hopefully I can swap these after work and give it another go.
    Last edited by hammslice; 03-23-2011, 04:26 AM. Reason: Did more thinking on this subject.
    1990 332is - work in progress.
    • hammslice
      • 120
      #62
      Originally posted by jakeb
      This drawing is really cool..... Do you have it in a higher res? I would make a large print and put it on the wall in my garage.
      When I get a chance I will scan it again. Just have the "screen res" version right now, but the original 8.5x11 is out in the garage.
      • Jason89i
        • Sep 2004
        • 875
        #63
        i think there are a few other things in the wiring you should look at. however, its a bit confusing thumbing through your notes. ive made an xl spreadsheet to help stay organized. it is probabily overkill, but it makes trouble shooting much easier if needed. make one for each vehicle, then just mate them up.
        pin# - wire color (harness) - wire color (chassis) - function - where to where
        cheers, jason
        edit: dont be fooled by dme label color. there are some red labels that have ews installed.
        • hammslice
          • 120
          #64
          I made the notes mostly at a computer and not out at the actual car. Now that everything is in the car, it may be easier to trace any errors. I have also printed the ETMs and will have them with me in the garage tonight.
          sneaky! first time i've heard that.
          • hoveringuy
            • Dec 2005
            • 2742
            #65
            That would totally be consistent with the problems you're having. It's been done many times before.
            Just to help confuse things, I have an early production SILVER label ECU that doesn't have EWS...
            • hammslice
              • 120
              #66
              SI reset is now in the correct place.
              Start Immobilizer is now in pin 16 but I'm not sure I fully understand this. I rechecked the ETMs and E30 Pin 16 goes between the diagnostic connector and the SRS module.
              RealOEM.com puts my DME from a car with a build date of 10/1993, so EWS should not be an issue.
              Still no start.
              I'm working on checking continuity and haven't come across any that don't make sense as of yet.
              • hammslice
                • 120
                #67
                i spent the night redoing my ETM research. i did it based on build date, pretty sure i used model year before, to see if it made a difference. i got the same result.
                C101 pin# Wire Color (E30 Chasis) Function Wire Color (E36 Engine) x20 Pin #
                1 Blue Alternator Blue 25
                2 Blue/Black Oil Lvl Static Red (Homemade)
                3 -- --
                4 Brown/Purple Coolant Temp Brown/Purple 12
                5 Black/Brown Oil Pressure Brown/Grey 23
                6 Green/Yellow Diagnostic Power/O2 Heater/Fuse 9 Green/White 22
                7 Green Switched Ignition/OBC Code Relay Green 21
                8 Yellow/White Fuel Economy White/Black 24
                9 Black Tachometer Black 20
                10 Purple/Green Oil Lvl Dynamic Green (Homemade)
                11 White/Blue SI Reset White/Green 19
                12 Brown/Black Check Engine Grey 8
                13 Purple/Red Fuel Pump Relay Green/Violet 13
                14 Blue/Yellow Speed Black/White 14
                15 Black/Green Starter Unloader Black/Green 15
                16 White/Black SRS Diagnostic/Not Used ??
                17 -- --
                18 Black/Yellow Starter Ignition Black/Yellow 18
                19 -- --
                20 Red/Yellow ABS
                x20 Pin # Wire Color (E36 Engine) Function Notes
                1 -- E34 Oil Lvl
                2 -- E34 Oil Lvl/E36 M3 A/C VANOS control
                3 -- Brake Signal (Auto Only)
                4 Black/Blue A/C Compressor Control
                5 Black/Grey A/C Pressure Switch
                6 Purple/Grey DME Climate Control
                7 Black/Violet Start Immobilizer
                8 Grey Check Engine Light
                9 -- M3 Oil temp
                10 Blue/Yellow Reverse Light Signal
                11 Brown/Yellow Coolant Temp 2
                12 Brown/Purple Coolant Temp 1
                13 Green/Violet Fuel Pump Relay
                14 Black/White Speed
                16 White/Yellow Data Link RXD
                17 White/Purple Data Link TXD
                19 White/Green Service Interval Reset
                20 Black Tachometer
                21 Green DME Power
                22 Green/White Reverse Light/Data Link Power
                23 Brown/Grey Oil Pressure
                24 White/Black Fuel Consumption
                25 Blue Alternator
                • e30rapidic
                  • 2167
                  #68
                  cam sensor and crank sensor connectors switched??
                  '87 325ic, powered by S50.
                  • samiam3356
                    • Jul 2009
                    • 1901
                    #69
                    Crank is male the the cam is female.
                    Originally posted by Roysneon
                    $5 shipped?
                    Originally posted by MarkD
                    You are a strange dude, I'n not answering any more posts from you.
                    • hammslice
                      • 120
                      #70
                      Tried another red label DME today. No go.
                      DME is known to have been working (e46s54dr ran it for two years). The VIN says its from a 95 525. I wonder if it has EWS? It appears to be unopened.
                      Too frustrated to really look at anything else at the moment. My key seems to be acting up now too. It only works sometimes when I put extra force inward on the key. Like the key cylinder isn't positioned properly.
                      • hammslice
                        • 120
                        #71
                        Just a short update: did some work with the multimeter today and verified continuity between every pin at the DME interface and the corresponding function location. Found nothing that didn't jive with te bentley diagrams. Also checked the resistance on all the injectors and they were all 14.7+/-0.1 ohms. (24lb).
                        Only thing that looked a little off was that the casing of the 240 ohm resistor in line from the coil pack ground splice to the thermostat flange ground was cracked. Resistance checked out though.
                        • hammslice
                          • 120
                          #72
                          No. Checked several times.
                          For OBD1, the harness connections are both female.
                          • samiam3356
                            • Jul 2009
                            • 1901
                            #73
                            Interesting, I have an s52 converted to OBD1 and they are different. Crank has a male connector FOR SURE
                            $5 shipped?
                            • 328ijunkie
                              • May 2007
                              • 3961
                              #74
                              have you tried verifying spark? pull a coil leave it plugged in stick a plug in it and ground it on a vc bolt.
                              Check Us out on Facebook
                              Full Product Line Tuning
                              • hammslice
                                • 120
                                #75
                                No Spark.
