Overlord475's S50B30US Build / Swap Thread
  • Overlord475
    • Dec 2010
    • 799
    Hey guys!
    This is the project thread for my 1989 325i S50 build!!! I'll be updating it as I move forward with the car and make progress.
    Project Beginning Car Specs:
    Model: 325i
    Year: 1989
    Color: Delphin Metallic
    Doors: 4
    Interior: Black
    Trans: Auto
    Motor: M20B25
    Project Current Car Specs:
    Interior: Dark Dark Brown
    Trans: 5spd
    Motor: S50B30US
    Pics from the day I picked her up! It was a really awesome experience. Flew out to St. Louis on New Years eve 2010. There was a really bad thunder storm so my flight got canceled. So I had to take a bus an hour south to Cape Girardeau where the car was. Then I got to drive 8ish hours home. But... It was all worth it because I picked the car up for just $1500 !!!
    Here is what I started with:
    S50US 3.0L M3 Engine w/ 70k miles (overhauled)
    - New main and rod bearings
    - All new timing components
    - Rebuilt Cylinder head
    - Rebuilt Vanos Unit
    - New Belts, Tensioner
    - Spark Plugs, coil pack connectors, and coil packs
    - New gaskets and seals
    - New Water Pump, Thermostat, Metal Water Neck
    - All New Sensors (E30 Gauge temp, E36 FI temp, O2 sensor)
    - Lime Green Block
    - Euro Oil Filter Housing
    - New Air Flow Meter
    - E34 oil pump, pan and dip stick
    - Custom E30 S50 Wiring Harness
    - 413 Silver Label ECU (Performance tuning w/ EWS Delete)
    - MLS Performance HG (~10.2:1 CR)
    - Stainless Steel Headers
    - E36 Throttle Cable
    - IE Offset Engine Mounts
    - Coolant Hoses
    - GripForce Light weight single mass Flywheel (14.5lb), with new clutch kit
    - Aluminum Godspeed Radiator
    - SPAL 16" Low Profile Rad Fan
    Also did a G260 5 speed swap at the same time.
    - G260
    - G260 Manuel drive shaft
    - White325 G260 Trans brace
    - Man. Pedal Assembly
    - New master cylinder
    - New slave cylinder
    - New throw out bearing
    - New hydraulic fluid lines
    - New Center Support
    - New Guibo
    - BluntTech short shift kit (30% Reduction)
    - All new shifting grommets and washers including B-clip
    - New selector and output shaft seals
    - Mr. Swiss Wiring Relay (retains cruise control)
    Brake / suspension work too:
    - StopTech drilled and slotted rotors
    - Rebuilt Calipers
    - ATE Pads
    - New Brake Lines
    - BluntTech 15mm Drop Hats
    - Rebuilt ZF Power Steering Rack
    - Tie Rods
    - Control Arms
    - Front and Rear Sway Bar links
    - Front and Rear Sway Bar bushings and brackets
    On to the S50B30US build
    Swap Week!
    Update (5-20-11)
    Brand New M-Tech II Wheel
    325is Trunk Spoiler
    Shadowlining the Window Trim
    Sorry, skipped a few steps....
    Euro License Plate Filler, Euro Front Grills, Blacked Out Kidneys, and KOPI Smoked Turn Signals
    Before...
    During...
    After...
    Plate Filler Before...
    After...
    Hit the max word count in this first post so all future updates will have to be as replays. These updates start on page 3.
    Car's current state
    --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
  • Reckless_Havoc
    • 156
    Nice start! I love the lime green. I painted my s50 block the same color.
    • rThor432
      • Feb 2007
      • 3907
      I like your flywheel-- not bad for a steel part. Did you have someone local do the work and what did it start out as (if you don't mind me asking)? It looks like you are doing everything nicely, you'll really enjoy it in the end when it's all done properly.
      • Mr.SWISS
        • Nov 2005
        • 1251
        PM me if you want some help as I have done a 24V and manual swap at the same time also. I can round up a BMW MofO or two perhaps to dig in.
        Originally posted by 325Projectz
        don't listen to the diagram... listen to mr. swiss.
        :nice:
        • greyis89
          • 230
          Man that looks killer!
          • Overlord475
            • Dec 2010
            • 799
            Thanks guys, I'll keep you posted on the progress...
            That would be awesome. The shop is just North of Owasso, and I'll probably be there everyday this week.
            • Lawson509
              • 100
              Man that is a clean car for 1500. Mine didn't looks like a pile compared to that and that is what I paid. And week is really quick, good luck.
              • green
                • Dec 2010
                • 128
                I remember seeing that on craigslist. Good score!
                • Overlord475
                  • Dec 2010
                  • 799
                  Day 2 update on 1st post
                  Will update day 3 and 4 tomorrow night.
                  • Holland
                    • Nov 2008
                    • 7212
                    Overlord, lord of the underworld. That is one nice car for that money and it seems like this isn't your first time in swap land.
                    Originally posted by DEV0 E30
                    • Overlord475
                      • Dec 2010
                      • 799
                      Originally posted by rThor432
                      I like your flywheel-- not bad for a steel part. Did you have someone local do the work and what did it start out as (if you don't mind me asking)?....
                      It's actually from GripForce
                      http://gripforce.com/store/index.php...roducts_id=384
                      Originally posted by Holland
                      ..... it seems like this isn't your first time in swap land.
                      It is my first time actually, ha. But, I'm an engineering student and I've done my research.
                      I'm not a half 'A' kind of person... So if I can't do it right or can't afford to than I won't do it at all.
                      Thanks for the complements guys! And yes, be jealouse because the car was a crazy steal at $1500 :D
                      • e30jan
                        • Feb 2011
                        • 133
                        Nice! S50 pulls hard :) i want to do this swap someday... My m20 is just tooo new to pull out at this moment.... The best of luck with the process. Ill save this thread
                        • Spiff325iS
                          • Jun 2004
                          • 1263
                          CLean swap action here.
                          The Red Dragon V.5 1991 318iS / 2013 F800GT
                          "You gotta fix the nut behind the wheel before you fix the bolts on the car"
                          • dude8383
                            • Jan 2005
                            • 10387
                            Where'd you grab the euro filter housing?
                            Coming along nicely :up:
                            • Mr.SWISS
                              • Nov 2005
                              • 1251
                              Housing came with motor. When I left he was getting ready to bolt up the G260 and the starter. Pending parts from Autohaus AZ we could have this wrapped by Sat.:yawn:
                              :nice:
