Exhaust cam put in intake m50nv?
  • dball4
    • 560
    Has anyone run two exhaust cams on a nv m50? just curious
    1989 M3
    2008 135i 6sp
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    Which exhaust cams? two S50's?
    • dave.a.cote
      • Jul 2009
      • 246
      I have a nv exaust cam sitting around - care to trade for a nv intake cam?
      1988 325 auto-x car
      1989 325ix winter car
      1991 525i summer car
      • dball4
        • 560
        Two stock nvm50 exhaust
        1989 M3
        2008 135i 6sp
        • Jand3rson
          • 37587
          Do it and report back what happens. We'll wait here.
          • shiboujin
            • Feb 2006
            • 2791
            you would.
            PS: your mother's a whore.
            • Jand3rson
              • 37587
              Best in 3 states. ;)
              • 328ijunkie
                • May 2007
                • 3961
                I has extra cam lol
                Check Us out on Facebook
                Full Product Line Tuning
                • HakenTT
                  • Feb 2011
                  • 47
                  Not that I know of. Makes no sense to do that, you will lose power. Cheap upgrade for Non vanos car is to get another non vanos intake camshaft and put it on the exhaust side, this way you will have a duration of 240 and lift of 9.7 on both sides, this puts you closer to the S50 camshaft specifications.
                  • dball4
                    • 560
                    Hmm thanks for the tip. I might have to do that
                    1989 M3
                    2008 135i 6sp
                    • dreamchasin
                      • 3892
                      Please do the dual intake cams. A buddy told me to do this with my NV M50 but before I go into dealing with a timing chain blind, I want some good outcome of it. Good luck.
                      90 325is alpine2 m50b25 becoming a dorifto car.
                      • Leo_328i
                        • 226
                        Aren't the M50 NV cams on both sides 240 degrees with 9.7 lift already? I've heard about this mod being good but cant work out why?
                        Leo.
                        E30 318iS, E36 328i
                        • HakenTT
                          • Feb 2011
                          • 47
                          On non vanos the exhaust side cam is like 225 with 9.0mm lift. More lift means cam lobe has to compress the valve spring further and that takes power. Cars with hotter cams lose low end power but gain peak power. What BMW did is put a camshaft that will result in best power/economy/emissions. So if you are not going to use your car strictly for racing then leave the cams alone.
                            • 34839
                            you use the S50 exhaust cam on the M50 intake side, and the M50 intake cam gets moved to the exhaust side. nobody uses two M50 exhaust cams.
                            • 5mall5nail5
                              • 156
                              My car made 685 rwhp with completely 100% stock M50 non vanos head, so I think BMW did a good job on the cam selection.
