Firewall clearnance issues... ideas?
    I've got my S50 in and running but the head is about 2mm away from the firewall which leaves no room for the wiring harness to mount.
    It's also causing the hood to have a difficult time closing....
    I shaved the firewall a little, but it doesn't seem like I could shave enough to make a real difference.
    Ideas???
    --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
    I'm assuming you already removed the rubber insulation on the firewall since you are shaving it down already.
    What engine and transmission mounts are you using? Sounds like your engine and/or transmission are sitting too high.
    M/S52 Wiring Diagrams
    Z3M S52 to late model 325i wiring diagram
    M52 to 318is wiring diagram
      It shouldn't be quite that close or tall. What bushings are you using?
        ^^ yeah, pictures.. my wiring runs on the cover for the heater. its held up by two small pipe type wall mounts lots of clearance everywhere..
        No more e30s for me.
        88 black BMW OBDII 332is dedicated track [sold]
        88 BMW OBDII bronzit 332is [RIP 03/08]
        91 BMW 325i [sold]
        86 Corolla 'Ae86' HB 20v trd [sold]
        http://youtube.com/watch?v=pTj7Hn9v5Rs
          Using the IE offset motor mounts, a white325 G260 brace, and stock height trans mounts.
