413 silver? 413 red?
  • e30gentry
    • 608
    What are the differences between the 413 red and the 413 silver?
  • herlsy
    • Sep 2009
    • 339
    Red does not have any EWS (drive away protection).
    Silver does have EWS, and will require a chip to 'remove' it. Unless you have all the components of the matching EWS system.
    • e30gentry
      • 608
      Sweet! That will make things easier!
      • hammslice
        • 120
        I've recently learned that there is some overlap. Late reds may have EWS and early silvers may not. The change over is January 1994 according to the bentley manual. If you are buying one, run the last 7 of the VIN at realoem.com to get build date.
        Last edited by hammslice; 03-25-2011, 05:17 PM. Reason: Typos due to damn iPhone autocorrect.
        1990 332is - work in progress.
        • herlsy
          • Sep 2009
          • 339
          Originally posted by hammslice
          I've recently learned that there is some overlap. Late reds may have res and walt silvers may not. The change over is January 1994 according to the bentley manual. If you are buying one run the last 7 of the VIN at realoem.com to get build date.
          I believe you are right on this one. I have a white label 413 that came out of a 93 525i, no VIN specific numbers on it. I believe there were some white labels that were factory replacements.
          • StereoInstaller1
            GAS
            • 22679
            Does anyone know for sure what the story is with the white label DMEs?
            I have one sitting...should it have EWS?
            Closing SOON!
            Thanks for 10 years of fun!
            • herlsy
              • Sep 2009
              • 339
              I'd like to know also. I have 2 white label ECUs, one 402, one 413. The 413 i have says 'made in spain', and i haven't been able to find a pic of one similar.
              I actually think white/silver may be the same color, mine don't look very metallic.
              • hoveringuy
                • Dec 2005
                • 2754
                I have a silver label out of a '94 with no EWS.
                • StereoInstaller1
                  GAS
                  • 22679
                  Hmmm, still no solid info.
                  MarkD STILL has not returned my email, I want stock S50 tuning without EWS.
                  No love yet.
                  Closing SOON!
