coolant/heat issues
  • Joe G
    • 2942
    coolant/heat issues
    So the first time i took the car out, it got hot(i forgot to bleed the coolant). I pulled over, shut the car off, and my expansion tank was overflowing like a mofo. I let the car cool down for 15 or so mins and then drove home (2miles) at around 50mph with the hood popped, and heat blasting. At this time the heat was blowing hot air.
    The next day i bled the coolant and took the car for a drive (45 mins) and it ran fine, no getting hot (temp gauge needle at about 5 degrees past vertical). But now the cars heat isnt working. Whats the issue?
    Current Car: 2011 BMW 135i, M-Sport, 6 speed
    Originally posted by lambo
    Sounds like you need a massage.
    Originally posted by kpeng
    Who the hell is Vlad?
  • nomansland92
    • 1657
    You might still have an air pocket. I had this problem for a long time.
    IX being restored here
    Ix turbo build here
    • FredK
      • 14752
      It could be that your thermostat failed in the open position due to the overheating. Replace it and bleed the system again.
      Godspeed.
      • Joe G
        • 2942
        If the car isnt overheating am i giving anything up/doing any damage aside from not being able to warm up the cabin on a cold and lonely night?
        • ck_taft325is
          • Sep 2007
          • 6880
          It's a bitch, but try dropping the coolant out and checking your thermostat. Hot pan of water, meat thermometer and see when it opens up (if it does at all).
          Replace if it needs and then bleed the system again. My vote is probably an air bubble. Are you loosing coolant at all? Is your driver's side foot well nice and dry?
          Need a part? PM me.
          • Joe G
            • 2942
            Everything is dry. But if the car isn't overheating, and I'm getting no heat I'm not at risk of doing any harm right?
            • ck_taft325is
              • Sep 2007
              • 6880
              As long as the coolant isn't disappearing and there's no white smoke, etc, you should be fine. I would keep investigating why you're not getting heat though. Could be a heater core valve is stuck or any number of issues. BUT, if you're not over heating, there's no Houdini coolant... you're good to drive. All cold and lonely.
              Need a part? PM me.
              • Joe G
                • 2942
                well the coolant level does go down little by little, so im going to check all my hose clamps tomorrow and see if there is in fact a leak. But there is no white smoke, and when it goes down its only a little bit at a time.
                • samiam3356
                  • Jul 2009
                  • 1901
                  Had a similar issue and my spider hose was colapsing by the firewall. Didn't notice until I was under the car and happen to look up and see it. Ended up having to put some clamps on it to keep it from colapsing.
                  Originally posted by Roysneon
                  $5 shipped?
                  Originally posted by MarkD
                  You are a strange dude, I'n not answering any more posts from you.
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    Head top
                    Spider bottom
                    Originally posted by 325Projectz
                    don't listen to the diagram... listen to mr. swiss.
                    :nice:
                      • 37828
                      Originally posted by Mr.SWISS
                      Head top
                      Spider bottom
                      Exactly, make sure your heater hoses aren't backwards.
                      Otherwise, bleed it again. There's no reason the heater shouldn't work and it's good to have it available.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • MattM
                        • Apr 2009
                        • 931
                        Head top
                        Spider bottom
                        umm, try again?;)
                        Full Build Thread Here
                        • Mr.SWISS
                          • Nov 2005
                          • 1251
                          Originally posted by MattM
                          umm, try again?;)
                          :nice:
