OBDII exhaust manifolds
  • Joe G
    • 2942
    So I'm running obdii manifolds and they are leaking. I thought the holes between 2 & 3 and 4 & 5 were the cause of said leak, so I fabricated 2 plates to cover them. After several test fits i have them on perfectly and completely seal the holes. But now the area where the manifolds bolt onto the block directly above the holes is the source of a new leak.
    You can see/feel the exhaust escaping from there. Granted its not nearly as bad of a leak as before, but its still driving me nuts. Do need to get some new OBDII exhaust manifold gaskets?
    Current Car: 2011 BMW 135i, M-Sport, 6 speed
    Originally posted by lambo
    Sounds like you need a massage.
    Originally posted by kpeng
    Who the hell is Vlad?
  • hoveringuy
    • Dec 2005
    • 2744
    You may have the wrong gasket for those manifolds. The usual fix is that you weld-up the slot from the back side and flat file it to match the head.
    • 328ijunkie
      • May 2007
      • 3961
      Which gaskets are you using? You can use a blockoff plate or weld the hole just fine as long as you keep using the OBD2 gaskets and assuming the mounting flange isnt warped.
      Check Us out on Facebook
      Full Product Line Tuning
      • Joe G
        • 2942
        Idk what gaskets. I'm assuming they are the wrong ones, cause it's leaking from the gasket area since I installed blocking plates.
