easiest brake booster to modify
  • M20power93
    • Feb 2011
    • 84
    I want to do an m50 swap into my 4door 325i, what's the easiest brake booster to use and modify (requires the least amount of fabrication).
  • blackhawkimpact
    • 2415
    Stock booster
    • M20power93
      • Feb 2011
      • 84
      how do you go about modifying the stock one?
      • e30rapidic
        • 2167
        944, just thread the rod further
        '87 325ic, powered by S50.
        • jaywood
          • Jul 2010
          • 4528
          Slot the holes in the firewall and slide it over
          • drulle
            • Dec 2008
            • 1906
            ^^ I just did it on my 325i 4door. Super easy to do. Instead of slotting the holes I just drilled 4 new holes 1/2" to the right. I still had to trim intake manifold fins for clearance. This gave about 1/4" gap between booster and IM. Hope this helps
            "i love vee tek, its a wonderful sound when you driving right by it"
            If you bought anything from me, please leave a feedback here: http://www.r3vlimited.com/board/show...ghlight=drulle
            • M20power93
              • Feb 2011
              • 84
              ^^this sounds pretty easy to do
              • glucklich21
                • 1912
                IX Booster. Drops right in and you just shave a few fins.
                • justin_l_
                  • Jun 2007
                  • 1079
                  and get a new master and remote resivoir.
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    I think I am going to go this route after not liking the modded E21 booster feel, really not caring to hack my firewall, and now the Audi booster hits the TPS too! So it looks like a remote res is the best setup with the 735i booster and master, and 2002 res.
                    Originally posted by 325Projectz
                    don't listen to the diagram... listen to mr. swiss.
                    :nice:
                    • M20power93
                      • Feb 2011
                      • 84
                      are there any modifcations that go with using the stock booster besides drilling different holes and perhaps shaving a little off the IM?
                      • drumad
                        • Aug 2009
                        • 1700
                        yes.
                        2008 335i - n54b30
                        1991 318i - m52b28
                        1994 fzj80 - LAND CRUSHER
                        • e30s50dan
                          • Nov 2008
                          • 2076
                          This
                          NASA
                          BMWCCA member
                          PCA member 25yrs
                          1991 318IS slick top
                          1997 M3 sedan
                          2001 325CI DD
                          “whoever turns the wheel the least, wins"
                          • z31maniac
                            • 17566
                            THR booster + new master cylinder + Massive Street kit is the route I went and the brakes were outstanding.
                            www.gutenparts.com
                            • crazyvwobie
                              • 298
                              Wow a post every week about this it seems.You are doing an engine swap the booster is one of the easiest things to do.I used 944 and simply threaded the rod a little some more ,pretty much a no brainer and seems much easierer and cleaner then drilling new holes and getting a new res and mc.Not to mention paid $25 dollars and brakes are great.
