Stripped this from my "build" post.
What are you guys doing with the e34 throttle cable? Are there different lengths? I am using one and have this issue. The distance between the bracket and the throttle arm is too far going through the bracket and grommet like it should. Its' about 1 1/2 inches too short. I removed the bracket but cannot flip it around due to the offset and vacuum line nipple. Any suggestions????? Do I need a certain model number? I already gave my e30 throttle cable away so that's not an option. Looks like I will have an issue when it comes time to hook the cruise cable up too....that cable bracket/housing is completely different. Any of you have pics of your setup?
Thanks
Thanks
