M50nv cam question
  • sennafan
    • Jan 2008
    • 205
    M50nv cam question
    I am gathering parts for my M50nv build with M52 crank and pistons. I want to move the intake cam to the exhaust side and get a shrick for the intake side. If anyone has done this, where did you get the single shrick cam and approx what do they cost. Thanks
    • 34839
    they are $$$ especially for 24v. try to find an S50 exhaust cam to use as an intake. I don't think a single schrick and an NV intake cam are going to be a good match anyway, the schrick will be significantly more agressive.
    • Mr.SWISS
      • Nov 2005
      • 1251
      You do realize either route the cams cannot be timed off the blocks. You have to manually dial them in. I would suggest a spinning the motor over a lot after you think you're done also.
      Originally posted by 325Projectz
      don't listen to the diagram... listen to mr. swiss.
      :nice:
