S52 engine noise
  • jasapp
    • 67
    There were two pulleys held on with 6 bolts, but no big thing with teeth.
    • Mr.SWISS
      • Nov 2005
      • 1251
      OMFG Why haven't you had any of the MofO's come help you out? Since when are crank hub bolts reverse thread... I have heard TTY but never left hand thread....
      So you get the other end out of the crank yikes.
      In case you are unaware, there are more swapped E30's in Tulsa and lotsa swapped ti's in OKC. We have a pretty strong membership check us here
      Originally posted by 325Projectz
      don't listen to the diagram... listen to mr. swiss.
      :nice:
      • jasapp
        • 67
        Usually I'm not so completely mechanically incompetent. Although, admittedly this is pretty f-ed up.
        I'll definitely keep an eye on that thread. I could sure use some moral support from other e30 owners over beer.
        • FredK
          • 14747
          Originally posted by jasapp
          Two pulleys, but no big black donut with teeth like I see here:
          Presumably I need one?
          Wow.
          Yes. Of course. You definitely need a vibration damper.
          • Wanganstyle
            • 2828
            Leak it down in the car before you remove it to see if you bent any valves on your shifting incident. if you think it went 7.5 k it may have gone a bit over that.
            Talk to your local machine shop as to how to remove it. its beyond normal DIY tools to remove half of a broken crankshaft bolt cleanly, its really really hard stuff.
            • brokenbimmer533
              • 317
              With no vibration damper your crank position sensor isn't getting any signal, but from that picture you don't have a cps either...
              • 328ijunkie
                • May 2007
                • 3961
                Are you running OBD1 or OBD2? idk who in their right mind would set a limiter at or above 7500 on an S52. And if you really are missing your crank pulley you couldnt be running OBD1
                And youre installing your motor mounts upside down.
                Check Us out on Facebook
                Full Product Line Tuning
                • Mr.SWISS
                  • Nov 2005
                  • 1251
                  Missing vibration damper
                  motor mounts backwards
                  Installing engine with A/c bracket all bolted on....
                  You know I bet Grant or iflytii would lend you some help they're in OKC and have swaps. Hell Bob is an OG swapper he had his running in early 05.
                  :nice:
                  • jasapp
                    • 67
                    Fair enough. Maybe I am.
                    I'm running OBDII, the CPS is on the back of the block. I have no idea what the limiter is set to, the only thing I've done is have the EWS deleted.
                    • 328ijunkie
                      • May 2007
                      • 3961
                      Can i assume you swapped a 318 and didnt change the coding plug? The stock limiter is 6800. Youre not revving to 7500 your tac just thinks you are.
                      • LJ851
                        • 7918
                        The S52 crank i have has the toothed wheel bolted to the crank inside the block.
                        Lorin
                        The M30 is God's engine.
                        • 328ijunkie
                          • May 2007
                          • 3961
                          ^Because youre running OBD2, he assumed you were running OBD1.
                          • jasapp
                            • 67
                            It's a grey market 323i. I bought an adapter from treehouse, and had to splice a wire into connector that goes to the cluster. The tach appears to work, but I don't know how accurate it is. I'll try and find out some how.
                            Like inside the timing chain cover or actually inside the block? I don't think I saw one when I had the pan off.
                            • 328ijunkie
                              • May 2007
                              • 3961
                              Stolen pic but look on the far left counterweight.
                              • 328ijunkie
                                • May 2007
                                • 3961
                                And whyd you buy a treehouse adapter?
                                The page you're looking for does not exist. Please visit our home page or locations page for more information.
