s50 swap help
  • phreshkid
    • 4655
    What's it with guys from Sacramento asking about quarter mile times from swapped cars lately?
    • jrdeamicis
      • Nov 2008
      • 956
      I can help you take care of your swap if you would like. Contact me. Well get it sorted.
      Past Car : E30 S50 6 Speed 5 Lug 3.73
      Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
      ___________________________________________
      BNB Designs
      Engine Swaps, Fabrication, Innovation, General Repair
      Richmond CA
      Julian 848-248-8029
      • JRKOUPE
        • Dec 2004
        • 3159
        Originally posted by mohamadr89
        Oh trust me I have been doing research it's just that I find a lot of different ways to do it so I just asked to get more ideas I guess. I'm going to start the swap really soon so I will keep everybody updated on what I run into. So u said u did a swap around 8 months ago, have u taken ur car to the tracks yet to test the 1/4 mile?
        I dont run 1/4 mile's...........just road courses.
        I use my big block Chevelle
        w/ 600 wheel hp to blow thru the 1/4.
        • highoutput
          • Apr 2011
          • 94
          Does anyone know....if the E36 engine mounts are just needed for S50 swaps, or do i need E36 mount arms for my M50 as well??? This is the first time I've seen it mentioned, I though I just needed the rubber mounts, cause I already have the mount arms that came on the M50.
          Thanks for the help.......
          OP, sry to jack your thread
          24V M50, M3 cams, Turner Tune, full exhaust, ect....
          • dude8383
            • Jan 2005
            • 10387
            Where did your M50 come from? An E34 or an E36? For the engine mounts you're going to want E28 535i mounts or AKG's poly mounts made specifically for 24v swaps.
            • highoutput
              • Apr 2011
              • 94
              Honestly, its OBD1 so I just assumed it was from an E34. Which has lead me to other confusing questions about the oil pan.
              Anyway, I guess I'll have to check the part numbers on it. Their must be a way to ID where it came from....I'm just not sure how yet.
              • bimmerteck
                • 762
                All OBD I tells you is that it was either produced earlier than 1996 or that it was a 1996+ motor that was converted. For figuring out what it is, assuming the donor motor is complete, look for a VIN sticker on the back of the cylinder head and post the last 8 of the VIN #.
                • AlpineS50E30
                  • 289
                  Originally posted by dude8383
                  i'm popping in simply to see where this goes, for entertainment purposes only though.
                  check out my swap thread =]: swap thread
