Another "Can Someone Make Me A Wire Adapter" Thread
I also do harness conversions. Adapters suck and look like dookie IMO
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
Really
He made mine.....no problems. huh
Gregslow sent me the wrong harness, I think I got mine for a m20 powered car, many of the pins aren't lined up. I am trying to solve this right away.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.Comment
seriously, it's easy to do if you spend some time researching. I'm in the process of pulling my adapter out and swapping on a C101 connector for that cleaner look....and removed all the unnecessary wires this afternoon. Also planning to move relays back to where they mount on an M20 harness and going to move the diagnostic port (just not sure where yet).
I hadn't done too much automotive wiring before but once you get in there and sort wires out and bundle together, its pretty damn easy. I did mine on the kitchen table in less than one hour.'87 325ic, powered by S50.Comment
It really is easy, and doing it yourself gives you some knowledge of the electrical system that you just might find useful if things don't go smoothly on completion.
If everybody poured over the ETms we'd have less "where does this plug go?" threads around here. And way less "why won't my car start threads?"
'89 Alpine S52 with goodiesComment
use the E30 M3 harness cover. there is a place for 4 relays inside the cover and the diagnostics port mounts on the drivers side of it. it's perfect. I hated that aux relay box on the M20, it always got in my way.Comment
I haven't installed it yet but Nando (Chris) did a clean job on my harness conversion! Pro work man!
We'll see how it works once my swap is complete but I'm sure it will be just fine.Last edited by ACHTUNG; 06-16-2011, 09:19 AM.1989 US E30 Cammed S52
Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
Proper way of doing the wiring :Dseriously, it's easy to do if you spend some time researching. I'm in the process of pulling my adapter out and swapping on a C101 connector for that cleaner look....and removed all the unnecessary wires this afternoon. Also planning to move relays back to where they mount on an M20 harness and going to move the diagnostic port (just not sure where yet).
I have parts for 2 more adapters and 2 more harness conversions
I have to finish butters' harness, poor dude - the guy he got the harness from hacked off all the relays, so I gotta fix that too. :(Comment
I need one of the covers....thanks for the reminderOriginally posted by blunttechAlways Always go for the reach around if there is an optionComment
^lol
If someone wants to ship me their OBD1/2 Harness i can repin it and make it so you dont need an "adapter"
:D
