almost done, need some help.
  • Alpine e92
    • 182
    Where does the smaller hose go? does it connect to the crankvent on the valve cover?
    And what about these two small wires? One comes from the fuse box and the other goes into the firewall on the driver side. Are the power or ground?
    Mounted my M50 in my E30 today but i have a few questions. The car is a 91 318i, 93 m50tu, and i'm using the getrag240 off my m42. what trans mounts do i use? i have a new set of 318i trans mounts but the way the engine sits now, its real close to the fire wall (up agaisnt it). also i need some help with the routing of the coolant lines for the heater core.
    Hope i can get this thing running soon.
  • Dj Buttchug
    • Jun 2010
    • 7637
    use the same trans mounts that came with your m42. its just a matter of adjusting the mount on the rails provided in the chassis.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Alpine e92
      • 182
      I have it adjusted up but it still seems off. How much clearence is there between the engine and the firewall?
      • Dj Buttchug
        • Jun 2010
        • 7637
        it should be close. not touching tho. How close is it?
        Ig:ryno_pzk
        • samiam3356
          • Jul 2009
          • 1901
          Back of the head goes to the bottom of the heater core. For sure! haha
          Originally posted by Roysneon
          $5 shipped?
          Originally posted by MarkD
          You are a strange dude, I'n not answering any more posts from you.
          • ck_taft325is
            • Sep 2007
            • 6880
            I can just barely get a finger in between my fire wall and S50 head. It's really, really close. "Fat guy in a liiiiiittle jacket..."
            Need a part? PM me.
            • Alpine e92
              • 182
              Yeah that's about where I have it now. Now the coolant hoses are my prob, and reaching those looks like fun.
              • greyis89
                • 230
                Great looking valve cover. Hope you're up and running soon.
                • Mr.SWISS
                  • Nov 2005
                  • 1251
                  With the intak on yea. On my NVM%0 swap I had to tighten the clamps on the heater core fro underneath, and it was a major BITCH. This last time we just pulled the mani and it was soooo much easier.
                  Originally posted by 325Projectz
                  don't listen to the diagram... listen to mr. swiss.
                  :nice:
                  • Alpine e92
                    • 182
                    Which hoses go where? My M50 came with some sort of valve on the hose off the back of the head, it splits off to two hoses. I can get a picture if needed. But idk if i needed it. I want to get this thing wired and all the coolants hoses ran today.
                    • jrdeamicis
                      • Nov 2008
                      • 956
                      E30s should have a bypass valve near the firewall for the heater core incase of overheat so the heater core doesnt explode. If I remember correctly the back of the head goes to the bypass valve then the bottom heater hose. The OBD1 spider hose goes to the top.
                      Past Car : E30 S50 6 Speed 5 Lug 3.73
                      Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                      ___________________________________________
                      BNB Designs
                      Engine Swaps, Fabrication, Innovation, General Repair
                      Richmond CA
                      Julian 848-248-8029
                      • Alpine e92
                        • 182
                        added a few pictures of things i need help with.
                        • e30gentry
                          • 608
                          [QUOTE=Alpine e92;2532199]Where does the smaller hose go? does it connect to the crankvent on the valve cover?
                          I believe your right the small one goes back to the connection on the cranvent.
                          • Matt-B
                            The Waffler
                            • 3856
                            yea, goes to valve cover vent on front of motor, on smaller nipple deal
                            • greyis89
                              • 230
                              Two wires from the fuse box go to power 12v distribution connection pasenger side battery tray area. Forgot to hook these up in my install and had smoke erupt.
