Weird fault code...Need Help
  • kalib0y
    • Dec 2004
    • 3620
    ***Finally fixed! easy fix too!***
    So after I've had the head fixed and the car is running great but Ive been getting this fault code over and over.
    car has 95 S50
    Used to be an automatic
    I get the Vehicle speed signal or Road sensor input error code.
    my speedometer works fine and I checked the plug in the diff.
    Is there a plug on the intake manifold or cylinder head that I am missing/forgot to plug in? I hope you guys can help me.
    Thanks in advance
    95 7.1L 16V E36 M3
    Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
    LIKE my Facebook Page! CLICK HERE
  • herlsy
    • Sep 2009
    • 339
    Is there a speed signal going to the ECU?
    • Matt-B
      The Waffler
      • 3856
      maybe your coding plug? or something is acting up
        • 34839
        your VSS is probably not connected properly
        C101 pin 14, black/white wire
        • kalib0y
          • Dec 2004
          • 3620
          Would removing the head affect the wiring? I mean they removed the wiring harness cover to remove the head but do you think that it could have jostled something around to disconnect the wires?
          95 7.1L 16V E36 M3
            • 37829
            No it's something that needs to be connected where the engine harness meets the chassis harness. The VSS is important to make the engine run best.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • kalib0y
              • Dec 2004
              • 3620
              So I pulled the adapter and saw some oxidizing on the pin 14 which I think is the VSS pin so I put some electrical connector grease so hopefully It solves the problem for now at least
              95 7.1L 16V E36 M3
              • kalib0y
                • Dec 2004
                • 3620
                So my remedy didn't fix it.
                Do you guys think the mechanic must have messed up the wiring harness adapter while removing and reinstalling the intake manifold?
                I might have to remove the intake manifold and trouble shoot...argh
                95 7.1L 16V E36 M3
                  • 34839
                  well if it's corroded you need to clean the contacts or perhaps replace the pins. dielectric grease isn't going to fix it as it's non conductive anyway.
                  what adapter is it btw?
                  there is nothing in the intake manifold that has anything to do with VSS. it's a straight shot from the C101 connector to the ECU.
                  • kalib0y
                    • Dec 2004
                    • 3620
                    im thinking that the tugging on the wires to get them out of the way may have caused the problem as this issue only started after the head repair job...
                    It's an M50 x20 adapter
                    1. I dont have any problems with my speedometer or tach...could it be a bad but not severed connection?
                    2. How does having this check engine light affect the cars performance?
                    95 7.1L 16V E36 M3
                      • 34839
                      I meant who made the adapter :p
                      the speedo gets it's signal right from the diff, then it's passed on to the ECU. your speedo working doesn't mean anything, excep that it's not the diff sensor. the tach is another wire altogether and is unrelated.
                      I'm not sure on specifics but it usually puts it into some form of limp mode, some people report poor performance.
                      • kalib0y
                        • Dec 2004
                        • 3620
                        a friend of mine made the adapter and its sits tight up against the intake manifold
                        95 7.1L 16V E36 M3
                        • kalib0y
                          • Dec 2004
                          • 3620
                          Im diving into the wiring diagrams and cant seem to find the pin out on the ECM for the VSS do any of you know what pin number it is? I have the red label 413 DME if that helps
                          95 7.1L 16V E36 M3
                          • 328ijunkie
                            • May 2007
                            • 3961
                            Check Us out on Facebook
                            Full Product Line Tuning
                            • e30rapidic
                              • 2167
                              Originally posted by 328ijunkie
                              42
                              yes, he is right as I have mine hooked directly into pin 42 on my red 413. I ran a new connector/wire from the spare pin of the green plug of the cluster to pin 42.
                              '87 325ic, powered by S50.
