Official Electric Fan wiring thread!
  • mpowerful
    • Jul 2013
    • 1273
    #196
    Did you put a 30amp fuse in?
    • E30Pacman
      • Jan 2014
      • 60
      #197
      ya i put a 30 amp fuse. should i be puttin a bigger one in?
      "We at BMW do not build cars as consumer objects, just to drive from A to B. We build mobile works of art."
      • mpowerful
        • Jul 2013
        • 1273
        #198
        Nah id think that would be plenty. Maybe someone with a spal can chime in on that but i cant imagine it pulling more amps than that.
        • bmk
          • Feb 2011
          • 598
          #199
          Originally posted by 328ijunkie
          Simply have the power wires that went to
          The stock fan fire the relays built into
          The Volvo fan, then run fused power and ground to the fan relay
          Since its a low and high speed do I need to order the 3 prong coolant temp sensor? (im using a e36 radiator with the volvo mounted as a pusher for clearance)
          Worlds 1st LS powered e30 cabby.
          Cab
          billac: 92 Lagunengrün cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
          Raphael: 88 Lagunengrün IX + Hella 500's + Red ACS type 1's
          Shaggin Wagon
          : 01 325xiT 5 speed
          91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
          88 CRX OEM+ 42mpg DD.
          • 2mAn
            Señior Mod
            • 20284
            #200
            so I am tackling the pusher fan project and I have some questions, but first the pics of what Im starting with. My car is an 84
            As listed in the OP, this is before the plug. Black/Blue, Black, Green & Brown. Obviously, nothing is connected to it.
            Looks like I have to place an order for a 2 or 3 prong temp sensor. If I want to add A/C, i get the 3 prong, correct? 61-31-1-364-272 = 2-prong, so whats the part # for the 3-prong?
            ok, I actually sourced an A/C setup (still need the E36 A/C compressor), but this appears to be a late model setup. Not sure what to do with it.
            So heres what I know. I need to get the temp sensor to make it work properly, but is there anything I can do in the interim with what I have?? I doubt it, but I figure I'd ask. Fan is already mounted and I tested it to make sure it was setup as a pusher and I know which wire needs to be grounded and which goes to 12v to actually make it blow air.
            Simon
            Current Cars:
            -1966 Lotus Elan
            -1986 German Car
            -2006 Volkswagen Jetta TDI
            Make R3V Great Again -2020
            • raudonis
              • Jan 2013
              • 184
              #201
              cluster tells I'm overheating before electric fan switches on
              Can the engine start overheating before rad coolant reaches 88° to activate the temp switch? Cluster tells me engine is overheating before the fan switches on.
              Have installed a 16" SPAL puller instead of the clutch fan. It is switched by the 82/88° switch screwed in the top of the radiator. New rad, new hoses, new thermostat, new coolant, new waterpump.
              Wiring is good, fan turns on if i jump the wires connected to the temp switch.
              Tried two different new temp switches, both activate ~88° in a glass of boiling water with a cooking thermometer. And 88° is really too hot to touch the glass.
              I know thermostat opening is good, because engine gets pretty warm, before bottom rad hose starts suddenly getting hot.
              Warm coolant is getting to the rad, but judging by the touch it doesn't seem to get nowhere close to 88° before my cluster is telling me that engine is overheating.
              If I put the HVAC blower on full hot blast and jump the temp switch wires to turn on the fan, the engine cools down to the point of thermostat closing - bottom rad hose gets cold. My cluster is toasted?
              My transaction feedback on r3vlimited :):Clickety click
              • ArtClassShank
                • Jul 2013
                • 143
                #202
                Try bleeding the system again. Also could be your cluster, solder's on the temp gauges like to get worn down and give you funky readings. Easy enough to pull the cluster and check, with cooling, you're gonna want an accurate gauge.
                1989 Carbon Black 328is
                • raudonis
                  • Jan 2013
                  • 184
                  #203
                  System is bled - otherwise there would be no hot air from the HVAC blower.
                  I've made a remote battery box for the Si-board as one of the original batteries was not putting out any Voltage and there was some minor acid leakage.
                  Looking for temperature/impedance graph for the cluster temp sensor to track engine temp using Ohmmeter. Sensor # 62110788115.
                  About to try Si-board delete: http://static.flickr.com/106/294049943_805192b84d_o.jpg
                  Might try another temp gauge or adding solder to the ground point. The readings aren't erratic of jumpy, just seem incorrect.
                  • 328ijunkie
                    • May 2007
                    • 3961
                    #204
                    Cluster. I have about 100 cluster parts in the back of teh shop and can stick 20 different temp gauges in each different cluster and they all read different. Best thing we do here (when running OBD2) is 'calibrate' the needle to read according to what the ECU is seeing. Middle should be 195 or so depending on your thermostat.
                    Check Us out on Facebook
                    Full Product Line Tuning
                    • 2mAn
                      Señior Mod
                      • 20284
                      #205
                      As listed in the OP, this is before the plug. Black/Blue, Black/Green & Brown. Obviously, nothing is connected to it.
                      I guess nobody saw my post??? Its been 100 degrees here this week, so I wired up the fan to get switched power. It runs all the time now when the car is on, which I hate, but not as much as I would hate for my car to overheat. I want to buy the sensor but I dont know if the 2 prong will work if/when I install A/C. I also couldnt find the fan switch wiring either the other day, but it was kinda dark. I'll have to look again
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      • raudonis
                        • Jan 2013
                        • 184
                        #206
                        Reading about e-fan conversion for teh mighty Euro S50, got another idea about my problem.
                        All factory BMW rads have AC-fan switch holes on the cool side of the rad (above bottom hose).
                        Thermostat is 80°, thus temp switch for the fan must be no more than 80° and mine is 88°.
                        Found 2 other switches to try with the same thread and wiring contacts:
                        FAE 36310 (Rover OE # PEJ 10006) 77°-72°
                        FAE 36320 (Saab OE # 88 57 443) 60°-45°
                        • 328ijunkie
                          • May 2007
                          • 3961
                          #207
                          You want the fan switch slightly above the thermostat like the suggested setup (80c thermo 82c switch) or it will be running near constantly
                          • 2mAn
                            Señior Mod
                            • 20284
                            #208
                            Can someone answer my questions? Here are some stupid ones:
                            #1 There is only one "group" of wiring for the OEM fan. the bk/grn, bk/blue, brown BEFORE plug then red, black, brown AFTER the plug, yes?
                            Technically, yes. There is two groups though. One for the fan and a second for the fan switch
                            #2 Since I have nothing AFTER the plug, can I simply use the BEFORE plug wiring (bk/grn, bk/blue, brown)?
                            Yes
                            #3 the fan wiring (2 wires, ground & 12v) can NOT go directly to the plug wiring, so the switch needs to be utilized, correct?
                            The electric fan wiring will go directly to the fan wiring, sounds like common sense now that #1 is answered
                            if the answer to ALL of the above questions is yes, then how exactly do I wire it up. If any of the questions are NO, please shed some light on what I need to do.
                            After reading the original post several times, I get lost after one part. It says to wire the electric fan to the AFTER plug wiring. 12v fan -> Red, ground -> brown. If I dont have the AFTER plug stuff, would the equivalent be 12v fan -> bk/grn, ground -> brown? So now, where does the switch get wired into???
                            Now, If any of my stupid questions has the answer NO, heres the next set of questions that I have.
                            #5 Is there a second plug that I cant find somewhere?
                            Yes, there is the wiring for the stock fan (shown in pics as the before and after plug wiring), the second group is a black/green, black/brown and black wire for the fan SWITCH wiring
                            #6 Do I need to hack the AFTER plug wiring I have from the late model stuff so the fan is wired per OP, 12v to red and ground to brown?
                            No, you can use before plug wiring
                            #7 where do those corresponding wires plug into my early BEFORE plug? bk/grn -> red, bk/blue -> black, and brown to brown?
                            not applicable as you can use the before plug wiring
                            The other part would also mean that I am not finding the second plug, and thats the wiring that goes to the switch?
                            Im lost, and its been hot here so the fan is wired to an external switch and I can power it up whenever, but I want the car to decide when it wants the fan on so I can focus on driving.TIA
                            my problem was that the car had already been modified and when I got it back I got confused because there are two black/green wires, one on the plug but a second one which was for the fan switch. and its actually green/black on the plug and black/green on the fan switch wiring. Hope this helps others who get confused
                            Last edited by 2mAn; 06-10-2014, 09:13 AM. Reason: answered my own stupid questions now that I have answers, just in case other people have the same question
                            Simon
                            Current Cars:
                            -1966 Lotus Elan
                            -1986 German Car
                            • 328ijunkie
                              • May 2007
                              • 3961
                              #209
                              Just wire your aftermarket fan to the stock fan wiring you still do have there basically :P
                              As far as running an additional manual switch basically tap into the fan switch wires and run them into the cabin and just have it short around the switch. Low amperage trigger wires
                              • nyChris
                                • Apr 2012
                                • 395
                                #210
                                I am having an issue I haven't seen anyone else having in this thread, or any other that addresses electric fan installs.
                                I have a 16 inch SPAL fan installed exactly as described in the first post. The fan comes on as expected just before 1/2 on the temp gauge. The issue I am experiencing is when the fan kicks on it puts a serious load on the alternator to the point that you can hear the alternator struggling, and the interior lights dim. Additionally the idle starts to surge.
                                I am in the process of troubleshooting, but was hoping that someone has seen this before, and can point me in the right direction.
