my obd1 s52 swapped e30 died suddenly at an intersection a couple weeks ago and hasnt started since.
it sort of starts. revs up to about 800 then dies. if you give it gas itl run for a few seconds, but it runs extremely rough and smells like its running heinously rich.
so far we replaced the fpr because we thought it was over fueling, then the cam position sensor, and crank position sensor because the cam sensor failed a resistance test and we thought the timing might have been off.
we have tried two ecus, one is know to be bad and im questioning whether the other one is bad as well. weve tried two mafs also, i dont know where to go from here
its killing me not being able to drive my car:(
any help or suggestions would be much appreciated!
