Full DIY Vanos Travel Testing Video
  • 328ijunkie
    • May 2007
    • 3961
    :D
    Check Us out on Facebook
    Full Product Line Tuning
  • lolcantturn
    • 4588
    good video!
    Originally posted by TSI
    OEM+
    • samiam3356
      • Jul 2009
      • 1901
      nice work Dave
      Originally posted by Roysneon
      $5 shipped?
      Originally posted by MarkD
      You are a strange dude, I'n not answering any more posts from you.
      • graphikg
        • Jan 2008
        • 1614
        Ya very helpful. SO this is how you do it!
        • Dominic49
          • Feb 2007
          • 1373
          just had to do this last weekend on the dyno when we couldnt figure out why my vanos was not vanosing it still isnt that much but w.e it gets full travel when measured
          • 328ijunkie
            • May 2007
            • 3961
            Replace the seals??
            • hoveringuy
              • Dec 2005
              • 2722
              You may need to keep a rag over the VANOS unit or it will spray oil out of the vent hole.
              • 328ijunkie
                • May 2007
                • 3961
                I had just rebuilt and installed this one so yeah that will happen if the vanos is full of oil lol
                • Wishno87
                  • 6025
                  That was pretty cool. My Vanos solenoid is on its way out :(
                  • hoveringuy
                    • Dec 2005
                    • 2722
                    Solenoid is usually a works/doesn't work affair.
                    I also found that if the seals are old you may need a large air compressor to support the flow needed to test. Probably wouldn't work with a 3/4 hp/ 2 gal compressor....
                    (that could also be because I have 20 degrees of advance on the M54?)
                    • Wishno87
                      • 6025
                      Well im having this problem where when im in the range where VANOS should be activated sometimes it feels like a lazy pig and other times it just pulls like crazy. And sometimes in the middle of a pull I can feel it switching back and fourth. Not really sure whats up.
                      • ck_taft325is
                        • Sep 2007
                        • 6880
                        How are your seals/aluminum ring inside the unit? Have you had a glance at the actual shaft? I know mine is almost exactly like what you're describing where one pull it's "Holy fuck me sideways that's a lot of fast..." and the very next minute it feels not so "healthy" or "eager". I know for a fact that my actual VANOS "splined shaft" was/is suspect as it had a far amount of noticeable to the touch marring on the "smooth but scratched" surface.
                        Need a part? PM me.
                        • 328ijunkie
                          • May 2007
                          • 3961
                          ^ I would check your seals...
