What sway bar for m3 e30 with euro s50b30
  • Taper
    • Aug 2007
    • 69
    I try to install stock sway bar in may car, but is impossible
    Any sugestion?
  • ak-
    • 12422
    Nothing is impossible
    1991 325iS turbo
    • Reckless_Havoc
      • 156
      I think the IE bar will work. I have one on my us s50 car and m30 car. It fits both with plenty of room and it's a nice product.
      http://store.nexternal.com/ireland/s...ront-p237.aspx
      • M-technik-3
        • 18946
        But you are already a member of S14, why didn't you review the engine swapped section. There has been numerous people that have done this engine swap and discussed it.
        • e30polak
          • 6136
          You have to either put a spacer on the front sway bar mounts, or relocate the mounting point further forward.
          INSTAGRAM: @UNDR8D_EMPIRE
          • Adrian_Visser
            • Jun 2006
            • 2823
            If you do use spacers you will also want adjustable end links to get the preload back down where it should be. I still haven't put mine on yet and the car is super twitchy. Of course I'm only running an s52 with Racelands longtubes but same idea with the header interference.
            '89 Alpine S52 with goodies
            • Lag
              • Jul 2008
              • 358
              • Eric
                • 5142
                No way the IE bar will work, check out the link below for a picture of my E30's underside.
                Originally posted by M-technik-3
                http://www.s14.net/forums/showpost.p...78&postcount=2
                I don't really like the way it was done, I'm sure modifying the header created a loss in power a bit. If I had the time to do it over again, I'd figure out how to mount it in front of the oil pan like the E46's are done.
                Or just get some adjustable blade ones, cause you know, that would be easier...
                • greyis89
                  • 230
                  This has been hard for me with the m50 now in. Car has been wrecked and straightened in the front so nothing really lines up, I'm looking for one that's really adjustable and strong to properly fit.
                  • Lag
                    • Jul 2008
                    • 358
                    http://www.r3vlimited.com/board/showthread.php?t=193281 <- get a subframe from Tyler and you can mount the bar in front like the newer cars.
                    Sam
