intake manifold nut installed upside down :'(
  • lolcantturn
    • 4588
    My friend installed an intake manifold nut, you know, the ones with the built in free spinning washer, upside down, washer side up! I have no idea how, but I need to get it off to figure where I'm getting a vacuum leak from. Any ideas?
    EDIT: woah I just realized how vague this post sounds, I'll get a good picture of it tomorrow!
    Originally posted by TSI
    OEM+
  • Highway1
    • Jan 2009
    • 773
    • Myster-E
      Performance
      • 552
      Axe a hole into the intake manifold to access the nut better. its faster
      1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
      Visit www.BimmerHeads.com for all of your 12 valve needs!
      • FredK
        • 14764
        Use a nut extractor. It will cut into the upside down nut and allow you to remove the nut.
        • LJ851
          • 7919
          Ask your friend to remove the nut the same way he installed it.
          Lorin
          The M30 is God's engine.
          • lolcantturn
            • 4588
            you would think it's that easy :(
            I got it out though, heated up an 11mm wrench and bent it 90* and got dat bitch out!
            OEM+
            • NickMosca
              • 12
              Is it as upside down as your avatar? I am trying to get a visual.
              www.flickr.com/nickmosca
