I want to use b28 Crank And b25 rod NV (135mm) and M50B25 Vanos Piston to Stroke my M50,
What is the compression Ratio to this rotating assembly?
I used the b25 Piston to get higher compression ratio than b28 piston based on :
M52B28, 31.82mm Compression height
M50B25 (VANOS), 32.55mm Compression height
