starter replacement procedure: is it as awful as an e36
  • Mouse
    • 377
    Originally posted by BMW_TUNER
    Did mine the top bolt was the worst. It was so tight with the s50 and the 260 against the firewall I had to get an adapter that converted my Torx socket into an end wrench. After that it is a 1.5 job. If you don't have a threaded starter it may be easier.
    Sorry to revive an old thread, but I'm about to order an alternator for my 24v e30 and thought the threaded type was easier/better. Is this not the case?
    Eloy
    1982 528e - Sold
    1987 325e - Totalled
    1990 325is - Sold
    1997 540i6 - Sold
    1991 325ic - Sold
    2013 335i - Sold
    2005 X5 - Daily
    1991 318is - *work in progress*
    • BMW_TUNER
      • Jul 2006
      • 1386
      It is not easier to have the threaded setup when you are trying for do the top bolt, from above, because you can not put a wrench on the bolt and remove the nut like in a non threaded unit. In the threaded unit you can easily remove the bottom bolt blind because of the threading but the top is a different story.
      1989 332IS -S-Fiddy Four-Some weight removed.
      5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
      • Dominic49
        • Feb 2007
        • 1373
        why does everyone do the starter from the engine bay?
        • BMW_TUNER
          • Jul 2006
          • 1386
          I could not get to the top bolt from any other way unless I dropped the Tranny cross member and angled the engine and tranny.
          • Wanganstyle
            • 2828
            Even with my gearbox taking up crazy room in the tunnel I was able to remove the starter on my M20 from under the car. Seems much easier than from the top as I cant see anything. To attach the top nut (unthreaded starter) I used the large amount of extensions (underneath car in trans tunnel) to hold the e-torx bolt in place and put the nut on from the engine bay side - not fun.
            This is with a portly diameter 6 speed transmission and its X member still bolted to the chassis. with the 5 speed boxes there is more room, much easier from under the car.
            To reach the Top bolt you need a ridiculous amount of extensions -3/8" drive for clearance.... about 6 feet worth of them.
            the large OEM E-torx fasteners connecting bellhousing and engine are the proper length/thread
