starter replacement procedure: is it as awful as an e36
  • e30user
    • 36
    I have an S50 with e36 transmission. My starter decided to die, so I plan to replace it soon. After reading some threads, I was surprised to see just how miserable of a job this can be on an e36. Has anyone replaced a starter in their swapped e30? Is the job worse, easier, or about the same? Any additional tips?
  • rotarievtec
    • Jul 2010
    • 261
    Its not that bad. Just pull your intake manifold and get to it that way.
    Originally posted by NitroRustlerDriver
    I don silk gloves and place them into a sacred envelope made of magic and lined with Unicorn fur, seal the envelope with an adhesive made from strands of Gypsy hair and wrap the whole thing in a snazzy looking faux gold leaf paper, with elm leaf inlay from Costco. Unfortunately, by the time it gets to you, all of that fancy stuff will likely have been picked clean by the greedy postal service employees. Please don't be surprised to see just a plain envelope.
    • havand
      • Sep 2004
      • 171
      I think if you jack the car up you can get it... I was trying to replace my intake temp sensor from underneath with a long extension.... Ask me how I now know where the starter is.... Hint, sparks.
      • lolcantturn
        • 4588
        It's easy. Lift your fuel rail enough to remove the intake manifold and take the manifold off. The starter is easily accessible. I'd be surprised if it took you more than 45mins
        Originally posted by TSI
        OEM+
        • M-technik-3
          • 18946
          Books out at 5.4 hours but can be done from below with reasonable ease.
          • hoveringuy
            • Dec 2005
            • 2718
            Did mine in about an hour by removing the intake manifold...
            Unloader relay on the rebuilt one didn't work but I was too lazy to do the job again.
            • lolcantturn
              • 4588
              Originally posted by m-technik-3
              books out at 5.4 hours but can be done from below with reasonable ease.
              five hours?!!?
              OEM+
              • Wishno87
                • 6025
                Changing a starter on a 24V e30 is easier than a stock e30. I was pleasantly surprised to experience this.
                • lolcantturn
                  • 4588
                  Almost everything on the 24V is easier than an M20 haha. That's not to say that the M20 is a complicated motor, theres just a lot less BS nuts and bolts.
                  OEM+
                  • Wishno87
                    • 6025
                    Haha ya pretty much. Also the 24V starter can be done by one person in the engine bay whereas the M20 pretty much requires two people, one in the engine bay and the other under the car with like a bazillion extensions.
                    Edit: In before someone says "well I did an M20 starter with my hands behind my back and tools hanging from my scroat"
                    • bloodshot-e30
                      • 1494
                      15-20 minute job.
                      ^Back in the game^
                      BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
                      FS thread:
                      http://www.r3vlimited.com/board/showthread.php?t=214105
                      • ck_taft325is
                        • Sep 2007
                        • 6880
                        For serious though, I've done stuff with "tools" hanging from my scroat...
                        Need a part? PM me.
                        • M-technik-3
                          • 18946
                          five hours?!!?
                          Yes that is book time for an e36 starter.
                          • bloodshot-e30
                            • 1494
                            no seriously 15-20 mins
                            ^Back in the game^
                            FS thread:
                            • BMW_TUNER
                              • Jul 2006
                              • 1386
                              Did mine the top bolt was the worst. It was so tight with the s50 and the 260 against the firewall I had to get an adapter that converted my Torx socket into an end wrench. After that it is a 1.5 job. If you don't have a threaded starter it may be easier.
                              1989 332IS -S-Fiddy Four-Some weight removed.
                              5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
