anyone have a picture of the e36 pan in an e30?
  • weaksauce
    • Apr 2009
    • 550
    i know i'm supposed ot be using an e34 pan on the swap, but the thread about the tubular front crossmember got me thinking.... could an e36 pan be modified to fit with some welding? i have 4 e36 pans from various projects, but no e34 pans, and I'm too cheap to buy one (plus modifying one sounds like more fun anyway)
    so, is it just a slearance issue, or is it far more involved than that?
  • bimmerteck
    • 762
    It will cost as much if not more to modify your subframe and e36 pan. Go find a used e34 pan and thank me later. ;)
    • Eecen
      • Jun 2010
      • 1235
      You would essentially be making an e34 pan out of the e36 pans trying to make it fit...just get an e34 pan.
      • weaksauce
        • Apr 2009
        • 550
        it's only going to cost me welding supplies. i can buy a lot of mig gas and wire for $200
        if it just won't work in any way, then i understand, i was hoping someone had a picture of where it hits, so i can see it. I might drop mine in the car soon and just see. might be a good time ot look at dry sump kits..... :D
        i'm trying to avoid having my oil pan stick down 3 inches lower than the subframe.
        • bimmerteck
          • 762
          Your chances of successfully welding a used cast aluminum BMW oilpan with a standard mig are slim to none, just judging by the knowledge presented in the above sentence.
          It can work, and the guys running s54s are doing it for good reason, but it certainly isn't a cheaper/easier proposition for a standard swap. Going dry sump is an easy way to double you swap's budget overnight. ;) Seriously I can buy 3 or 4 NEW e34 oilpans and a skidplate from peerless or ejnight for less than it would cost to convert to drysump or modify the pan/subframe to use an e36 setup. (your time has to be worth something even if it's min. wage.)
          • samiam3356
            • Jul 2009
            • 1901
            lmao
            Originally posted by Roysneon
            $5 shipped?
            Originally posted by MarkD
            You are a strange dude, I'n not answering any more posts from you.
            • aaronmjr
              • Nov 2005
              • 82
              Does the E34 525i pan have to be from an M50 car? Sorry to thread jack.
              1990 M3 / 1998 M3
              • cabin
                • Dec 2006
                • 552
                Sell a few of your e36 pans, i got $75 when i sold mine. Why make things more complicated than they need to be?
                -Justin
                Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
                • highoutput
                  • Apr 2011
                  • 94
                  yeah........i got my E34 pan for $90 shipped, and that was from a salvage yard that still had to removed it. AND they threw in the oil pick up for free. I had it three days after ordering it.
                  I had the same crazy idea when i first started my 24V swap.......dont bother. As others have posted, I'm sure, there IS a guy on this forum that sells the altered oil pans and front sub frames..........Good luck
                  24V M50, M3 cams, Turner Tune, full exhaust, ect....
                  • BDSax
                    Junkyard King
                    • Mar 2006
                    • 3594
                    Damn, my junk yard sold my pan and dip stick for $25.
                    • highoutput
                      • Apr 2011
                      • 94
                      well.....mines carbon fiber
                      • Matt-B
                        The Waffler
                        • 3856
                        I deleted my pan
                        • lolcantturn
                          • 4588
                          I run an M42 pan. Works really great.
                          Originally posted by TSI
                          OEM+
                          • jrdeamicis
                            • Nov 2008
                            • 956
                            If your going to fab anything. Fab a tubular subframe.
                            Past Car : E30 S50 6 Speed 5 Lug 3.73
                            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                            ___________________________________________
                            BNB Designs
                            Engine Swaps, Fabrication, Innovation, General Repair
                            Richmond CA
                            Julian 848-248-8029
                            • hoveringuy
                              • Dec 2005
                              • 2735
                              What sucks is that you can go to JEGS and and they have 5 pages of aftermarket oil pans for small block Chevy and Ford.
                              We need a Chinese ebay oil pan.
                              What would the perfect design look like? E34 but shallower and wider?
