Quick question on m50b25 swap
  • JRector
    • Apr 2011
    • 453
    Ok so gathering everything I need before istart the swap. I understand that if i use my getrag 260 tranny ill have to fab up the brace and my shifter will be off just a bit. I also have the e36 tranny already mated to the motor. Which transmission should i go with?
  • samiam3356
    • Jul 2009
    • 1901
    Which do you prefer? I would have sworn by the zf tranny before driving my swap with the 260. Unfortunately for you this is a very debatable topic with no clear cut answer.
    For me, s52 with a 3.46s and a 260 is a perfect combination for ME!
    A lot depends on your application and what not.
    Originally posted by Roysneon
    $5 shipped?
    Originally posted by MarkD
    You are a strange dude, I'n not answering any more posts from you.
    • JRector
      • Apr 2011
      • 453
      Arent there 2 different transmissions for e36 the ZF and the Getrag 250?
      • 1mz
        • Jan 2009
        • 641
        correct, but many people use the g260 from the m20, or some like myself even use the g240 from the m42
        http://l0st0n3.mybrute.com
        http://l0st-0n3.mybrute.com
        Work in progress: 1991 318i m50 swap
        Feedback thread :up:
        I prefer having a female in the car at all times. They generally smell good, but you do have to put up with that hole in their face.
        • luis.e30325es
          • Feb 2011
          • 128
          i used the 260 that my car came with. so far feels good.
          maybe it depends if you're willing to do the work it takes to make that tranny work (make/buy tranny brace and twist shift link)
          • JRector
            • Apr 2011
            • 453
            Yes im willing to make brace work and the linkage..i got a buddy who is a welder. What did you do to your brace to make up for the 10degree shift?
            • Jand3rson
              • 37587
              Just get one of these. Couldn't be easier.
              • Roysneon
                • 4505
                I have a 260 on hand but I think I'm going to go with the 250 already on my M50 just to keep it simple. I'm going to test drive it a bit then figure out what diff to go with afterwards.
                Originally posted by mbonanni
                I am a pursit now.
                • JRector
                  • Apr 2011
                  • 453
                  Ok ill def be looking into grabbing that brace. What about the shift linkage?
                  • glucklich21
                    • 1912
                    I hate you Sam....
                    • luis.e30325es
                      • Feb 2011
                      • 128
                      i made my own brace, just like the one that is on the link that white325is makes
                      took me an afternoon to make with 1/4 steel. about 1.5 inches wide.
                      the shift linkage you can either cut and weld it back together with the twist adjustment, or get a small torch heat it up and twist it yourself, put one end on a vice, then use a 10mm socket wit extension and twist to the left. might need to do it little by little and try putting it on there until it fits right.
                      i got all this info by a lot of time spent on research, most of it on here, so those are my sources.
                      Goodluck!
                      • JRector
                        • Apr 2011
                        • 453
                        I appreciate it..the tranny/driveshaft issue was my only question. I believe the carrier bearing is flipped around and you can use the e30s driveshafts
                        • samiam3356
                          • Jul 2009
                          • 1901
                          Originally posted by glucklich21
                          I hate you Sam....
                          lol well I have a 3.15s sitting in the garage if I do go to a zf. BUT I'm liking the 260 so far.
                          $5 shipped?
