E30 M3 24v Swap Specifics. Differences from Standard E30?
  • aaronmjr
    • Nov 2005
    • 82
    There is tons of info about doing 24v swaps into all manner of E30, but between here, tech, BF.c and Google I haven't found anything specifically about what's different when swapping into an E30 M3. Here's what I have gathered so far:
    -It sounds like wiring a 24v harness for an E30 M3 can have it's own set of issues from year to year:
    -I should be able to use my E30 M3 drive-shaft with my ZF Transmission.
    -My 4.10 LSD is too tall for use with this swap, I will need to buy a different one.
    -I cannot use my transmission cross-member, I must use a standard E30 piece.
    What about my gauge cluster? I have seen threads with people who have swapped cars trying to buy E30 M3 clusters, does it just work plug and play?
    Any input you guys could provide would be great.
    1990 M3 / 1998 M3
  • aaronmjr
    • Nov 2005
    • 82
    Did I cover it all in one post? Any thoughts on the cluster?
    1990 M3 / 1998 M3
    • jrdeamicis
      • Nov 2008
      • 956
      The wiring wouldn't be too hard. Just take your time and be thorough.
      Past Car : E30 S50 6 Speed 5 Lug 3.73
      Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
      ___________________________________________
      BNB Designs
      Engine Swaps, Fabrication, Innovation, General Repair
      Richmond CA
      Julian 848-248-8029
      • tonywonder
        • Sep 2009
        • 1688
        try s14.net there might be better info there.
          • 34835
          you can use your M3 cluster if you get an E28 M5 coding plug
          • nrubenstein
            • 3148
            Your 4.10 is too short. It's initially counterintuitive, but higher numbers are shorter, lower numbers are taller.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • samiam3356
              • Jul 2009
              • 1901
              This, there is a whole section devoted to swaps there. However, most of those guys seem to be going with s54's now.
              Originally posted by Roysneon
              $5 shipped?
              Originally posted by MarkD
              You are a strange dude, I'n not answering any more posts from you.
              • ogbimmer
                • Jul 2010
                • 936
                theres a 4.10 with my m50 and its short as hell!! haha
                " WHY DO YOU NEED 300HP TO DO THE SPEED LIMIT?"
