Gunky reservoir water
  • graphikg
    • Jan 2008
    • 1614
    My coolant reservoir looks to have gunky water. When I unscrew the cap; there is a residue that has a gunky texture to it. It makes me uncomfortable. Also, there seams to be a few drops of coolant that drop from the engine inconsistantly when parked for a few days. HG has just been replaced and Tstat has been replaced not too long ago, and I have the aluminum tstat housing.
  • nates 87 325is
    • Jun 2011
    • 124
    Is the gunk discolored? Did you do the HG. yourself ? Maybe you got some oil in the coolant holes. Did the head get checked for worps? Just some ideas
    87 325is
    • Sagaris
      • Sep 2009
      • 2243
      If it is black chunks then it is the inside of your coolant hoses falling apart, replace them before it causes issues.
      • jrdeamicis
        • Nov 2008
        • 956
        Hello Grinil.
        I did the head gasket for him.
        I did the thermostat housing gasket while had it apart since your old one was shit. Along with the thermostat seal.
        Allu thermostat housings are notorious for leaking.. Look for the leak there.
        Past Car : E30 S50 6 Speed 5 Lug 3.73
        Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
        ___________________________________________
        BNB Designs
        Engine Swaps, Fabrication, Innovation, General Repair
        Richmond CA
        Julian 848-248-8029
