E30-m52 wiring adaptor
  • jimbob88
    • Jul 2011
    • 18
    hi guys im just about in the middle of my m52 swap and have started to look into the wiring aspect of it, there is a guy on another forum that supplies a custom made loom for £120 but as always i like to look around and see if i can save any money anywhere :)
    i have heard talk of a wiring adaptor that sits bewteen the 2 looms but cant find any info on it
    any of you guys used anything like that?
  • Leo_328i
    • 226
    I've been looking into this recently as well as I have a 1998 M52 2.5l sitting in my garage now :) From what I've found, the wiring is actually very similar to OBD1.
    What E30 is this going into?
    Leo.
    E30 318iS, E36 328i
    • jimbob88
      • Jul 2011
      • 18
      its the 89 vert i have as my avatar, it was an m20b25, soon to be m52b28 w/ m50 mani, bbtb, lightweight m20 flywheel, software and N02 :)
      • SwiftE30
        • Jun 2010
        • 998
        Nice to see another vert out there with a 24v swap! I just actually finished dropping in my s52 w/obd1 conversion into my 89' vert. THey are going to need some serious reinforcements in the rear to eliminate chassis flex. Did you have any plans in mind?
        1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
          • 34844
          there's lots of adapters out there, some made by forum members and others from some of the BMW tuning companies in the states. I don't know about europe.
          if you want to make one yourself you'll need to download the ETM for your car and the car your engine came from, write down pin #s for the C101 (E30) and X20 (E36), then match up the functions.
          I'd suggest if you're going to do it yourself, just convert the harness to a C101 plug and skip the adapter altogether. it's cleaner and cheaper (if you're buying pins/plugs new).
          I can also make one but it costs money. :p
          • jrdeamicis
            • Nov 2008
            • 956
            OBD2 takes a little more adapter work but not much.
            Past Car : E30 S50 6 Speed 5 Lug 3.73
            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
            ___________________________________________
            BNB Designs
            Engine Swaps, Fabrication, Innovation, General Repair
            Richmond CA
            Julian 848-248-8029
