So after running the car hard at autoX, the car becomes hard to start. its as if the fuel pressure has to rebuild. it usually takes 2-3 long cranks before starting
Once it gets going, throttle lags if i step on it and the car just doesnt seem to be pulling as hard as it should.
after some research, it sound like it could be:
check valve in fuel pump
pressure regulator
Does this make sense? is it possible the 318 fuel pump isnt enough for the m50?
thanks
pressure regulator
thanks
