Identify this valve cover.
  • SkorcherX
    • Jun 2011
    • 267
    So both of these valve covers are for NV M50's. However one has the typical threaded hole for the coil cover mounts, and the other has these rounded nubs.
    I cannot find the coil pack cover mounts that could fit the nubs. I was told that the nubs unscrew... I have not been able to unscrew them. Any advice here would be greatly appreciated.
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Put a pair of vicegrips on the largest diameter of the nub.
    • 5mall5nail5
      • 156
      Its the bottom of the rubber bushing that you mount the cover to. You can ditch it or replace.
      • Jand3rson
        • 37587
        Yep, someone ripped the rubber bushing off of its metal base, and what's left is that round nub.
        One of mine was so stuck I actually had to drill it out, and then Andrew re-tapped the hole and added a threaded insert.
